  #51
Old 10-31-2011, 02:59 PM
progtox progtox is offline
Thumbs down Re: PT9 Import Session Data crash
i've lost 3 hours tonight and i haven't solved the import session crash!
[bleep][bleep][bleep][bleep] AVID...!
Now you want my money for Pro tools 10 ?
[bleep][bleep][bleep][bleep]!
  #52
Old 10-31-2011, 04:35 PM
gives's Avatar
gives gives is offline
Default Re: PT9 Import Session Data crash
So, It looks like from your Sgnature, you are still on 9.0.0? Why.. THere were problems with that from the beginning. Go to 9.0.5.. VERY stable for me. I have a lot going and never any problems. That is just one thing you might think about if this is the case. The other is repair permissions after you have closed everything down..i.e. all apps beforehand. Good luck!
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
  #53
Old 10-31-2011, 05:36 PM
sorry my old signature. I've the 9.0.5 and i've got all i can
permission
reboot
preferences
and so on...
He decide (pro tools)...he decide a project must crash...always...
Another project with same settings, same tracks, same band...all the same...perfect...another one...always crash when import some things from other projects. All random...but the same damn bug!
  #54
Old 10-31-2011, 07:30 PM
gives's Avatar
permission
reboot
preferences
and so on...
Gotcha..:)
Volumes? Protools prefs and database helper is great.. I still use that.
  #55
Old 11-01-2011, 10:46 AM
jeremiahmoore jeremiahmoore is offline
I've had the bug a couple of times here where the session cannot be saved, and PT is running out of memory.
Something is causing a memory leak, which can be observed with Activity Monitor. I can't recall the exact amount, but maybe it's dangerous when PT utilization is > 2GB or something. (search the DUC, there's a thread detailing it.)
In each instance I've been able to repair the project by:
- creating a new blank session at same settings (bit depth / sample rate etc)
- import tracks EXCEPT video tracks
- fwiw, at this stage I also eliminated (by not importing) 30 or 40 tracks of old OMF import tracks which were disabled.
- re-import the most pertinent video(s)
Quite frankly, I've no idea if the video exclusion helps. I just read somewhere that it might be an issue so I tried it. I've made no attempt to isolate the issue.
Perhaps I've been lucky, but in two instances on large projects this has helped.
Also: since this time, I now only import Quicktime and OMF via the import dialogs. Someone asserted that drag-and-drop import was related to causing the corruption, and indeed I've not experienced it since following that advice.
-jeremiah
ps - if Digi / Avid is interested, I can supply session docs which are corrupted with this bug.
9.0.1 doesn't fix the Import Session Data crash poly915 macOS 4 01-07-2011 01:53 PM
Session Data import function from 8.0.4 to 9.0.0 leads to a PT crash Franco1967 Pro Tools 9 27 11-27-2010 03:31 AM
New bug? Import Session Data - Crash - Missing Video Ryan Young Pro Tools 9 0 11-15-2010 12:33 PM
Import session data causing crash in 8.1 jval Pro Tools TDM Systems (Mac) 5 08-19-2010 10:57 PM
7.4 repeatable import session data crash fman Pro Tools TDM Systems (Mac) 0 11-22-2007 11:44 PM
