Re: Pro Tools 9 Crossgrade/Activation Issue
Thanks
You could email the Avid store prior to buying it just to check. at [email protected]
hey i was having an issue with my crossgrade on a digi 002 and found this thread on google. fyi turned out that i was reading an "A" in the serial number as an "R" because of the font they used. maybe that helps somebody...
Fortunately my 003R box was readily accessible and I was able to put it under a really strong light to read the serial number...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
However with PTLE crossgrades, you have to have a hardware serial number to activate PT9. And yes this is the hardware serial number on the unit. I had no issues crossgrading my system. :)
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
That means, even when I only have a hardware serial number from an old interface, which I don't have any more (in my case the mbox 2 mini, but I still own the serial), I can do the crossgrade without having the mbox 2 plugged into my computer? I ask only for the unlikely case, that during the installation the installer checks, whether the hardware with this serial is really in use or so...
thanks a lot!
Pro Tools 11 Crossgrade LE activation problems please help! | listening-books | Pro Tools 11 | 1 | 12-13-2013 09:38 AM |
Crossgrade from LE to 11 activation issue | nhlogan | Pro Tools 11 | 5 | 07-20-2013 07:59 AM |
Pro Tools 10 LE Crossgrade Activation Problem | BBKBB | Pro Tools 10 | 3 | 10-07-2012 01:58 AM |
Pro tools LE crossgrade issue | melodymaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-11-2011 09:35 PM |
Crossgrade activation | Electrik | macOS | 1 | 03-22-2011 10:53 AM |
