ALL-LINKED feature on channel strip not working?
Hi all
I recently had a play with the channel strip dynamics module. I'm inserting it into a 5.0 dx stem (as a 5.0 multichannel instance, not multi-mono) for overall compression. What I would like is to have equal gain reduction on all channels as soon as one of them hits the threshhold. According to common sense as well as the manual the ALL-LINKED setting should do just that, however when I insert a trim, unchain it and increase the level of just the center I can see that only the C gain reduction increases... The only way to get what I need is by using a side chain and trigger it from C channel... Could someone confirm this behaviour or kindly let me know what I'm doing wrong? Thanks a lot! M |
Re: ALL-LINKED feature on channel strip not working?
Hi Ceri
Thanks for testing this, from the screenshot it looks like you did it in PT 11.... Could u possibly try it quickly in 10, which is where I failed to do it... Cheers M |
Sure thing. Same result.
https://dl.dropboxusercontent.com/u/...ked%20PT10.png Happy to take a look at your session if you wanted. Let me know. C |
oh this is very curious.
I just tested it on my laptop and its working fine, but I swear its not working as expected at work on 10.3.5 and LION.... I will triple-check on Monday... thanks for testing Ceri |
Channel Strip | YYR123 | macOS | 1 | 03-02-2013 08:45 PM |
Channel Strip Bug | UnderTow | Windows | 2 | 10-23-2011 08:52 AM |
feature request on strip silence | clusterer | Post - Surround - Video | 4 | 09-20-2007 12:53 AM |
Feature Idea - VCA Linked Parameters | airon | Post - Surround - Video | 3 | 02-15-2007 04:39 PM |
Renaissance channel vs Channel Strip | frenchman | Tips & Tricks | 1 | 09-20-2003 05:18 AM |
