Command 8 vs 002R monitor section
Hi Folks,
Which would have the better monitor section between the Command 8 & the 002R & why? I would guess the Command 8, but I would love to have all the facts… Cheers N |
Re: Command 8 vs 002R monitor section
Anyone?
N |
Whichever is most convenient to you.
It's not rocket surgery |
I will be honest, I was hoping for a slightly more technical reply…
But thanks for taking the time to reply to my post anyway… On the main Digi site the Command|8 is listed as having ‘Flexible Focusrite onboard monitoring section’ Where as the 002R is listed as having ‘Outputs 1 & 2 mirrored on 1/4" TRS monitor output (with dedicated volume control)’ So we can assume that the Command|8’s monitoring section is made by Focusrite & the 002R’s monitoring section is made by Digidesign. So they are not identical & ‘Convenience’ only comes into play for me if they are both the same… But the big question for me is; which is better for audio quality? Cheers N P.S. I though this one would have been discussed to death, I even spent 15mins trawling through the search function & could find nothing… |
great question. I would like to know to????????
My "convenience" answer stemmed from the fact that I had both a 002R and Command8 in the same room for a long time. I primarily used the C8's monitor section, but would sometimes use the 002R as another headphone output (and I used the 002R as my main monitor section prior to purchasing the C8). I noticed no appreciable difference between the two monitor sections.
They are both middle-of-the-road at best and if you're "serious" about tweaking out your monitoring capabilities/quality, then I'd suggest a dedicated outboard monitor device from a company like Coleman Audio (no affiliation), Dangerous Music, CraneSong, or (on the cheap) Presonus. Bottom line, if you've got both in front of you - listen for yourself in your room and come to your own conclusion - that's the only possible way to make a decision. Otherwise, again, use whatever's most convenient to you.
Command 8 monitor section is really noisy | frnak | ProControl, Control|24, Command|8 | 6 | 07-12-2011 05:24 PM |
Quality of Command 8 monitor section with Digi 96? | Ru_C | Pro Tools TDM Systems (Mac) | 3 | 07-24-2010 11:04 PM |
D Command Monitor section cutting out | funkysax2002 | ICON & C|24 | 1 | 05-03-2010 07:07 PM |
Command |8 Talkback Section? | swimfan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-20-2004 08:04 PM |
PC monitor section | nworb ecnal | ProControl, Control|24, Command|8 | 0 | 03-15-2002 11:33 AM |
