Bounce the exact same length every time?
In Cubase, I can set project markers for where my song begins and ends, so when I bounce out versions or stems, they are always exactly the same length. Is there a way to do this in Pro Tools? If I set markers is there a way to tell it to bounce between them? This would be super helpful when I’m sending out files for people to do overdubs too.
Thanks |
Re: Bounce the exact same length every time?
You can save a memory location as a “selection” and recall it for the bounce.
What I do is have an empty mono audio tracker the top of the session that I drag across and make Clip Group (you CAN do that with empty space). I select that when I do my Bounces and it stays the same. You can also place a 2-pop, sync tone or a count-off in that Clip Group and track.
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
Drop markers, highlight from marker to marker. Zoom in to fine tune.
I never use markers, for what it is worth. Impementation of markers in PT is nothing to brag about. Bouncing, I always select timeline for exact time I want to bounce.
Like Kerry says; just make a selection across the timeline for the length you want, save a memory location with "selection" and zoom (if you want) as the attributes. Then all you need to do is select that marker and bounce/commit. In my sessions it's part of the template so the 'print' selection is always on the same marker. Memory Locations / Markers are fairly powerful and can be almost anything: location, selection, zoom level, show/hide tracks, group enables, etc.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
In case anyone is interested, my bounce markers is a track full of silence and a clip cut from that nonsense. Simple and sample accurate, can have as many as you wish. Never use PT markers.
I just create a MIDI track as the very last channel and create a selection. Click on it to select it and bounce the same exact length every time. I also create a fadeout on the Master mix fader in case there's any slight reverb that could get cut off.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I import (or create) a reference mix and always grab that just before bouncing. It's become second nature now but starting off a bounce without the correct length selected used to be something that caught me out almost every other time.
Thank you...all this time I thought it must be me!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Bounce file length | keithcstrat | Pro Tools 12 | 6 | 10-22-2017 05:04 PM |
Is there a quick way to pare down clips to exact length of waveforms [solved] | SigFriedChicken | Pro Tools 12 | 2 | 03-13-2017 08:53 AM |
Max length of a mp3 bounce from pt10? | kie von hertzen | Pro Tools 10 | 1 | 02-12-2017 04:00 AM |
Bounce to Disk: Bounce to disk length is longer than my track on my time | dijitalhorse | Pro Tools M-Powered (Mac) | 1 | 02-23-2016 06:27 AM |
Song bounce length | Dj-Ike | Pro Tools 12 | 7 | 01-18-2016 05:55 PM |
