Program Change to change Expand presets
Hello there,
I am pretty sure this is very easy to achieve, I just need to change presets from Expand automatically, I.E change from preset 4 to preset 7 in different sections of the song. Thanks a lot |
Re: Program Change to change Expand presets
Xpand doesn't do program change. You'll need to double up with two instances. One on the first patch and the other on the second.
Hi there, thanks for fast response,
Can I use another Virtual instrument in protools for program change? Thanks |
Some of the Korg Collection responds to Program Change messages - Wavestation for one, so there are at least some VIs out there. You'll probably have the best luck with VIs that mimic actual hardware units. As far as Xpand goes, there are some creative ways to change patches between the A-D parts. You can use CC messages to turn the individual parts on and off. You can also automate the volume slider for each part. So if you're a CC kinda guy go for it. Otherwise two separate instances is by far the easiest way.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
I think Hybrid 3 may be able to process program changes but I’ve never used it
Brian Hudson |
Thanks a lot for you replies, very helpfull
12.7 Program change bug | redj | Pro Tools 12 | 2 | 02-07-2017 11:02 AM |
Program Change (PC)? | jamesleonard | General Discussion | 29 | 09-30-2015 05:09 PM |
Program change | Fitzgrade | Pro Tools M-Powered (Win) | 3 | 08-05-2012 09:47 AM |
Own Program Change Map | Martin.Jirsak | Pro Tools 10 | 0 | 05-02-2012 07:28 AM |
Mdi program change | mksnz | MIDI | 0 | 07-03-2005 09:42 AM |
