Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 10-08-2018, 12:42 PM
Nolan-Nalon Nolan-Nalon is offline
Default PTF quits at startup - directing to Playback Engine
Hello
I am brand new to Pro Tools, but have used Logic for many years.
I have a new windows laptop and would like to experiment using Pro Tools for DAW work on the go, but have run into an issue, and would really appreciate some help.
The issue:
PT First starts up and then pops up this message:
Welcome to Pro Tools First!
Before you get started, you will be directed to the Playback Engine, make sure that the proper audio playback device is selected.
I press OK to acknowledge this message, and then nothing happens (the application seems to quit)
I have tired to press N during startup - no change.
PTF ver: 2018.7.0
OS: Win 10 home (very latest patches)
H/W: Dell XPS 9370 i7, 16 GB RAM, 500 GB SSD, 2 TB HDD
Audio: Built in / native Realtek Audio interface (which is also preferred as I will use this device on the go)
Any help or suggestions would be appreciated
Old 10-09-2018, 07:49 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: PTF quits at startup - directing to Playback Engine
PTF requires that you have an ASIO compatible audio interface, which most internal sound cards are not. Although I generally don't recommend ASIO4ALL, you could give it a try to see if PTF will run on your system. Don't expect great performance when using it though.
It should however get you past where you are now with PTF, then you can decide if you want an external ASIO audio interface for your laptop.
Will K
System Details
Old 10-11-2018, 12:02 PM
Thank you very much for your advice, Will - very much appreciated.
I wasn't aware of that restriction. I will explore the asio4all option and, if it works, perhaps consider an external portable asio interface option.
Regards
Nolan
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Trouble bringing up playback engine on startup boycie Pro Tools Software (Win) 1 05-29-2014 06:49 AM
PT 10.3.3 Unexpectedly Quits when Save As, Playback Engine Change, etc. JLIT Pro Tools Software (Mac) 9 03-05-2013 07:12 PM
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... dbC4G Pro Tools 9 11 03-09-2012 07:23 AM
pt 7 quits on startup edwardo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-28-2006 08:31 AM
