Focusrite OctoPre Mkii to 003+ via ADAT?
Hey,
I've been searching message boards and forums and haven't found my answers yet, was wondering if someone could help me out. I just picked up the OctoPre Mkii and am trying to hook it up via lightpipe. I'm running out from the octopre to the in on the digi003 and am not getting signal in ProTools from the focusrite. I'm getting signal on the octopre itself and am wondering if I haven't set up things right within the software. Please walk me through what I should do. thanks! |
Re: Focusrite OctoPre Mkii to 003+ via ADAT?
Did you go to Setup>IO and add the paths for the lightpipe inputs? They appear as 9 thru 16(17&18 are for the SPDIF input).
I've gone in, I guess I'm not getting how to assign the paths.
Im in a similar situation but I have a profire 2626. I made an assumption that I go adat out of the focusrite to the in on the profire. What I am looking or is what do I plug in where and then what needs to be done in Ptools if I want the pro fire to be the master and the clock source. I will check the IO suggestion above for now.
Thanks |
You can get away with a single lightpipe IF(big IF) you use the external device as the clock source.
How to connect the Focusrite OctoPre MKII to PT10 ? | Deadlocks | macOS | 5 | 07-10-2012 08:49 AM |
ADAT not being received in PTLE8 (OctoPre MKII) | justindbutler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-03-2012 09:36 AM |
LS56 with 2 Octopre MKII no ADAT signal | smbirddog | macOS | 6 | 06-02-2011 11:35 PM |
Two issues with PTLE 8.0.4 and Focusrite OctoPre MkII | sonicmosaic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-31-2011 11:15 AM |
Presonus Digimax D8 vs Focusrite OctoPre MkII? | DJ Hellfire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-19-2010 08:15 PM |
