Can't import audio in PT 12
Hi Everyone!
A couple of weeks ago, while working on assembling a record PT stopped letting me bring in outside audio files. When I click to import audio, an error message comes up. Anyone know how to fix this, or even just a way around it? It happens in all of my sessions, new and old across multiple hard drives. The error is pasted bellow. Could not complete the Import Audio command because Assertion in "/Volumes/Development/158347/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 573. |
Re: Can't import audio in PT 12
Hi, You might try a repair of permissions on the drive in question.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
1) Try working from a different drive and see what happens
2) Try trashing prefs and database/catalogs (use Pete Gates' utility)
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Thanks for the replies! I tried repairing disk permissions to the drives, and that didn't seem to do it. It happens regardless of what hard drive I'm on.
So now I'll try dumping the prefs and such. Rich, can you give me any more advice on how to do this? I'm not aware of "Pete Gate's Utility". Thank you all again for the help! |
Oh, awesome! Thank you!
I should have searched for it first. I'm pretty lame and new to the ways of forums. |
Hi again everyone!
I tried clearing the prefs via PG, and working off 5 different hard drives, but I'm still getting this error when I try to pull in audio files. Any other thoughts? If I could do this session in wavelab, at this point I would just go that rout. Here is there error again - Could not complete the Import Audio command because Assertion in "/Volumes/Development/158347/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 573. (Use the Copy button to copy this message to the clipboard.) |
try this to see what is happening .. if you open a Blank Session and go to import audio dialog box - can you play the files in there before importing ?? and what format does PT say they are ?? cheers john
It's always a good idea to check for illegal characters in any of the filenames, or in any of the folder or drive names that are in the path to the files. I have had illegal characters cause assertion errors in the past. May not help, but worth a look.
Scott Gatteρo |
Import Video - Audio Import Option Disabled | sarcanon | Pro Tools 12 | 2 | 06-14-2016 05:12 PM |
Does "Automatically Copy Files on Import" work with Import Audio command? | leftalive | Pro Tools 10 | 3 | 04-17-2013 09:35 PM |
Import Session Data with out Audio import | disinfor | Pro Tools M-Powered (Mac) | 7 | 11-14-2010 11:44 AM |
Import Audio search window results will not import | BA Studios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-25-2008 09:00 AM |
Re: Import Audio or Bounce to Disk then Import | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-10-2005 03:52 PM |
