  #21
Old 06-05-2017, 04:59 AM
Audiosweeet Audiosweeet is offline
Default Re: MacPro 5,1 sweet spot?
Originally Posted by Barry Johns View Post
Yes, if you do not delid the CPU's, which is so easy it's crazy, then yes, you have to use the spacers and the strips, which I own enough of them to do 50 upgrades, bought them before I learned how easy it is to Delid and still have them.
What is your delidding process? That parts freaks me out the most. I found a 4,1 machine with dual 2.9s which I may load up and just see how it all runs before doing the upgrade. How sure shot is the firmware upgrade? Any reason why it wouldn't take?
2011 Macbook Pro ML 10.8.5 2.5ghz i7 16 gigs 256 gig SSD Pro Tools 10.3.10 and 12.3.1, 002r, Command 8
  #22
Old 06-06-2017, 09:48 PM
Barry Johns Barry Johns is offline
I know this sounds scary, if you are not comfortable, buy a bunch of old CPU's for pocket change to practice on.
Take a utility knife blade, start working slowly around the edges of each corner slicing between the heat sink and CPU, it's soldered very solid, so it's not easy to get very far into the solder. ATTN: Don't slip and cut your finger off!!!!!!!
Place the CPU in a vice, with one side against the green CPU board, the other against the heat sink. Make 1/8th turn, 180 degree rotate, keep repeating until it seperates.
The CPU will be covered with silver solder. Take another utility knife blade and begin to scrape the old solder off, try hard to not scrape the green board the CPU is attached to. Eventually the solder will all go away, keep cleaning with 95% rubbing alcohol.
I have a detailed post recapping my experience, I will try to find it and copy a link here as well.
Don't be afraid, after you've done it, you will be amazed how simple it was to do, but its natural to be intimidated doing it the first time.
Going the spacer rout is fraught with potential issues, and I do not recommend it. I read numerous post/articles where people screwed up thier CPU's by over-tightening.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
  #23
Old 06-06-2017, 09:54 PM
http://duc.avid.com/showthread.php?t=370850
  #24
Old 06-06-2017, 10:00 PM
Here is another forum, where I found a ton of information about the upgrade. You also see I have a post there, going into a little more depth, than I did here at the DUC.
http://www.reduser.net/forum/showthr...94#post1543894
My post is on page 11 of the thread.
  #25
Old 06-07-2017, 01:23 PM
Great stuff Barry thank you!
  #26
Old 06-07-2017, 03:27 PM
There is a known issue with Siera that there is a fix for.
https://www.ifixit.com/Answers/View/...Upgrade+Solved
  #27
Old 06-08-2017, 03:12 AM
I will be mostly working in Mountain Lion but will definitely keep that for later. Could i just throw my SSD from my MBP right into the Mac Pro and be off to the races/upgrades?
  #28
Old 06-09-2017, 10:16 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
Maybe. Obviously, you'll need one of the adapter trays. You can definitely boot off the MBP drive using the Mac Pro.
Yes, what Barry mentioned is really similar to how I did mine. $20 Amazon vice works fine. I used some gaff tape to protect the chip. Wrap in a rag loosely just in case it pops off. Mine didn't. Mine had to be finished by slight pressure from two razor blades. Fast and easy. I used a card to push most the solder off. Razor to clean off the neoprene seal. Very find sandpaper and a bit of alcohol to finish the top CPU clean off.
  #29
Old 06-10-2017, 05:32 AM
What if i went through the PCIe slot with this jammer?https://www.amazon.com/OWC-Accelsior...dapter+mac+pro
  #30
Old 06-19-2017, 09:34 AM
arche3's Avatar
arche3 arche3 is offline
I have one of those. It works fine. I also have the next one they made that's faster. But both work really well and I can't tell a difference in speed.
Sent from my SM-G955U using Tapatalk
Using carbon copy to move from macpro to a newer Macpro fourthtunz Pro Tools TDM Systems (Mac) 2 04-10-2012 02:39 PM
A smaller, more focused sweet spot. mikevarela Post - Surround - Video 1 03-27-2012 09:16 PM
Spot function will not Spot?? frequencypoet Pro Tools TDM Systems (Mac) 4 02-08-2010 11:29 AM
PC and analog console - how do you share the sweet spot? Inaam ProControl, Control|24, Command|8 1 01-24-2003 03:43 PM
AD8K input levels: "sweet spot"? EJolson Tips & Tricks 0 12-19-2001 11:38 PM
