Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
  #21
Old 03-27-2017, 12:10 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Omni with 192 Issues/Questions
I've never tried to do exactly this but shouldn't you be able to setup the Hardware and IO panels to do this?
Basically Mirror the outputs of Ch1-8 to the ADAT connections? I assumed this was possible.....maybe I am wrong but definitely worth poking around in there to try to find out.
But if push comes to shove and all you have to do is create another track and assign in/outs....it's not a major setback.
Daniel
  #22
Old 03-27-2017, 01:14 PM
seanmccoy seanmccoy is offline
Well, I tried assigning the 192 outputs to ADAT but no go, so apparently there's no internal path from A/D to ADAT out. My guess is those are only addressable by audio coming out of Pro Tools.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
  #23
Old 03-27-2017, 01:41 PM
YYR123's Avatar
Ahhh, ok gotcha.
Daniel
  #24
Old 03-27-2017, 04:15 PM
Keep in mind that the optical outputs of the 192 will not work at all until properly configured under Setup>Hardware(inside PT). By default, digital IO is NOT set to use the lightpipe connections(IIRC, it defaults to AES). Getting the ADAT setup is not exactly intuitive(as I found when trying to use both ADAT in/out for an OctoPre preamps and headphone outputs). Once that is configured, you MIGHT be able to route with some AUX tracks that would not chew up system resources
  #25
Old 03-27-2017, 05:17 PM
Agreed, definitely not intuitive. OMNI is a little squirelly, too. Pretty amazing that units at this price point have such limited routing options. Avid could take a few lessons from RME where that's concerned. I'll have to figure out the ADAT I/O eventually, as that's the only way I can record digitally in real time from Logic into Pro Tools.
Just got my Omni. Some questions... PostHuman Pro Tools TDM Systems (Mac) 9 06-03-2023 02:06 PM
Omni-192 Expansion Questions seanmccoy Pro Tools HDX & HD Native Systems (Win) 3 02-10-2017 09:16 AM
HD io & Omni Interface Questions noah330 Pro Tools 12 19 06-28-2016 10:36 AM
couple of questions about Omni hookup musicmixer04 Pro Tools HDX & HD Native Systems (Mac) 7 02-28-2015 07:35 PM
2 questions ...Hd omni question, native, imac doyoung123 Pro Tools HDX & HD Native Systems (Mac) 8 06-12-2011 05:31 PM
