11.3 Jerky Graphics
I have the new PT 11.3 running on Yosemite 10.10.1 and my graphics, play cursor and fader movements, are very jerky and not smooth.
It was a clean install of Yosemite and PT 11.2.1 and then I ran the 11.3 installer. I have trashed prefs and rebooted. (com.avid.ProTools.Plist and the ProTools folder in the Avid folder) (are there any more?) Even with only one audio track playing it gets a little better, but still jerky. CPU usage with 1 track is 0%. While running 3 AIR synths usage is 6%. Memory stays a 32%, Could this be a problem with the AIR synths not ready yet? I understand that if they load at startup they can affect the system even if not used. Or maybe my old "Early 2009 Mac Pro" can't keep up.
John Clavin - AKA: Old Horseface |
Re: 11.3 Jerky Graphics
Maybe, what's your specs? SSD's all around?
So I removed all plugins from the Plugin folder, deleted prefs, and rebooted.
On startup, ProTools loaded only the 27 Core Audio Plugins. I created a new session with with 16 mono tracks of pink noise and nothing on the inserts. The situation is the same, jerky movement of the play cursor and difficult to move a fader up and down when in play. Playback buffer set to 1024. Usage 0%. Memory 24%. It seems to be a graphic problem, maybe with my vintage of Mac Pro. No one else seems to be having this issue.
What worked for me was to not have any windows opened in the background. Only the mixer window. Edit Link to my thread: http://duc.avid.com/showthread.php?t=362128
MacBook Pro 15-inch with Retina Display OS X 10.10.3 2,3 Ghz Intel Core i7 8 GB Pro Tools 12.2 / Logic Pro 10.2 / Reason 8.3 Remi Last edited by remideflon; 12-20-2014 at 04:42 PM. Reason: Add link |
Yes, with only the mixer window open the faders work normal.
In ProTools 9 (OS X 7.5) I always had both the mix & edit windows open with no problems.
I'm glad this isn't only a issue on the retina display. Now I just hope they fix these issues. So, after almost 3 months this is not a stable release.
MacBook Pro 15-inch with Retina Display OS X 10.10.3 2,3 Ghz Intel Core i7 8 GB Pro Tools 12.2 / Logic Pro 10.2 / Reason 8.3 Remi |
I had the same issues this weekend. I found my 002 console was somehow overloading the system. I disconnected it and used the internal audio out and everything ran smooth. Even with the new drivers installed it didn't help at all... although it did make the faders work again?
I had a weird thing happen in both pt 10 and pt 11 where too much pasted text in the comment area in the track. that text caused the spinning wheel to go nuts.
sensitive pt is sometimes!
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
Same jerky graphic on my machine a 12core (bench 32900) PT 11.3 on OSX 9.5 absolutely fresh installation. It makes me going crazy so many money for a jerky protools - cannot believe this. Please AVID hurry with a fix!!
Cheers Tom |
Jerky quicktime!!! Still!!! | kava | Pro Tools TDM Systems (Mac) | 2 | 12-01-2010 02:06 AM |
PT mtc jerky ? | Aquarius | Pro Tools TDM Systems (Mac) | 0 | 07-30-2010 04:35 PM |
7.1 Running Jerky | Papajelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-16-2006 11:00 AM |
Jerky graphics and problmems with... play | Przemek | Pro Tools TDM Systems (Win) | 2 | 01-31-2006 10:23 AM |
Jerky Video in 6.1 | chrille2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-04-2003 10:04 PM |
