#21
Re: MacPro 5,1 sweet spot?
What is your delidding process? That parts freaks me out the most. I found a 4,1 machine with dual 2.9s which I may load up and just see how it all runs before doing the upgrade. How sure shot is the firmware upgrade? Any reason why it wouldn't take?
2011 Macbook Pro ML 10.8.5 2.5ghz i7 16 gigs 256 gig SSD Pro Tools 10.3.10 and 12.3.1, 002r, Command 8 |
#22
Take a utility knife blade, start working slowly around the edges of each corner slicing between the heat sink and CPU, it's soldered very solid, so it's not easy to get very far into the solder. ATTN: Don't slip and cut your finger off!!!!!!! Place the CPU in a vice, with one side against the green CPU board, the other against the heat sink. Make 1/8th turn, 180 degree rotate, keep repeating until it seperates. The CPU will be covered with silver solder. Take another utility knife blade and begin to scrape the old solder off, try hard to not scrape the green board the CPU is attached to. Eventually the solder will all go away, keep cleaning with 95% rubbing alcohol. I have a detailed post recapping my experience, I will try to find it and copy a link here as well. Don't be afraid, after you've done it, you will be amazed how simple it was to do, but its natural to be intimidated doing it the first time. Going the spacer rout is fraught with potential issues, and I do not recommend it. I read numerous post/articles where people screwed up thier CPU's by over-tightening.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp Last edited by Barry Johns; 06-07-2017 at 02:44 AM. |
#23
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
#24
Here is another forum, where I found a ton of information about the upgrade. You also see I have a post there, going into a little more depth, than I did here at the DUC.
http://www.reduser.net/forum/showthr...94#post1543894 My post is on page 11 of the thread.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp Last edited by Barry Johns; 06-07-2017 at 02:41 AM. |
#25
Great stuff Barry thank you!
#26
https://www.ifixit.com/Answers/View/...Upgrade+Solved
#27
I will be mostly working in Mountain Lion but will definitely keep that for later. Could i just throw my SSD from my MBP right into the Mac Pro and be off to the races/upgrades?
#28
Yes, what Barry mentioned is really similar to how I did mine. $20 Amazon vice works fine. I used some gaff tape to protect the chip. Wrap in a rag loosely just in case it pops off. Mine didn't. Mine had to be finished by slight pressure from two razor blades. Fast and easy. I used a card to push most the solder off. Razor to clean off the neoprene seal. Very find sandpaper and a bit of alcohol to finish the top CPU clean off. |
#29
#30
Sent from my SM-G955U using Tapatalk |
Using carbon copy to move from macpro to a newer Macpro | fourthtunz | Pro Tools TDM Systems (Mac) | 2 | 04-10-2012 02:39 PM |
A smaller, more focused sweet spot. | mikevarela | Post - Surround - Video | 1 | 03-27-2012 09:16 PM |
Spot function will not Spot?? | frequencypoet | Pro Tools TDM Systems (Mac) | 4 | 02-08-2010 11:29 AM |
PC and analog console - how do you share the sweet spot? | Inaam | ProControl, Control|24, Command|8 | 1 | 01-24-2003 03:43 PM |
AD8K input levels: "sweet spot"? | EJolson | Tips & Tricks | 0 | 12-19-2001 11:38 PM |
