Old 06-20-2006, 03:25 AM
peter99 peter99 is offline
Default mono or stereo aux busses for effects
just wondering
what are you using for reverbs and delays... mono or stereo?
Old 06-20-2006, 04:23 AM
Andre Knecht Andre Knecht is offline
Default Re: mono or stereo aux busses for effects
If an effect has a mono input it only makes sense to use a mono send.
If an effect has a mono output it only makes sense to use a mono return.
If an effect has a stereo input it makes sense to use a stereo send bus feeding it.
An effect with stereo outputs is best served by a stereo Aux for its return path. Use the return’s Aux pan controls to determine the width and position of the effected signal.
Some plugins will accept a mono input and create a stereo output. In those cases, PT will automatically convert an Aux channel from mono to stereo. Feed these with a mono path.
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 06-20-2006, 05:59 AM
Drew Mazurek's Avatar
Not quite. Making the aux mono or stereo only determines how many inputs it will have. If PT changes a mono aux when a stereo plug is inserted, only the outputs are changed, it's still fed by a single aux.
drew
www.drewmazurek.com
Old 06-20-2006, 07:55 AM
How's that different from what I wrote?
Andre Knecht
Old 06-20-2006, 08:39 AM
sounded different in my head at 8am.
www.drewmazurek.com
Old 06-20-2006, 02:48 PM
A pre-coffee send?
Andre Knecht
Old 06-20-2006, 04:48 PM
lukeyy lukeyy is offline
IHTH.
as far as I know most of the reverb plugins have mono and stereo input... you can choose
maybe my question wasnt specific enough - I was wondering if you guys use mono sends (and route it to a mono to stereo reverb) or do you use stereo to stereo sends..!
Old 06-20-2006, 06:43 PM
Use whatever makes sense with a specific situation. That’s how I approach things every time.
The variables are so many* that it would take 71.4% of eternity to describe all the available avenues. And even then, the fact remains that there really are no rules. Experiment with the options at your disposal — it’ll teach you more than you’ll ever be able to glean from a handful of posts (even if extremely well-written).
* Nature of source; nature and number of available reverbs; use of reverbs on other tracks, function of the source within the arrangement; nature of the piece; nature of the act; etc.
IHTH.
[…] maybe my question wasnt specific enough…
Your question? Could this be the first schizophrenic post on the DUC? Are you peter99 or lukeyy? Are there more of you?
Andre Knecht
Mixture of Mono and Stereo busses jeremy@jjlee.com VENUE Live Sound Systems 5 12-06-2012 12:59 PM
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 06:36 AM
How to split a stereo bus into 2 mono busses zenstone Tips & Tricks 3 02-16-2011 06:05 PM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 10:01 AM
I only get 16 mono busses... Ante 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-02-2009 09:58 PM
