Old 03-07-2010, 09:30 PM
dalaolv dalaolv is offline
Smile mix knob on MBOX 2
hi all, i am new here.just got a mbox 2 for 2nd hand,protools 7.0 version. i found that the mix knob on the front panel's available range just from zero to 3 oclock position. the volume wouldnt goes any higher beyond that point. one of my friend got a same mbox 2, has the same question. just wish to check with you guys here, is that normal? thanks a lot!
Old 03-08-2010, 01:17 AM
AdamPT8 AdamPT8 is offline
Default Re: mix knob on MBOX 2
When you listen to it fully to the left, you are listening to the audio that is coming in, in real time, when it is always to the right you are listening to the audio that is coming through the computer.
It is best to have it fully to the right, then there will be no delay between recording and playback.
Old 03-08-2010, 04:01 AM
irishharry irishharry is offline
I find that if it's fully right, the latency between what I'm playing and what I'm hearing is off putting. So I put it to about 10 o clock and mute the channel I'm recording onto so I hear the playback mixed in with my direct input sound. Then if the recorded track doesn't quite match up I just move the region on the Edit window.
Old 03-12-2010, 02:25 AM
they are quite helpful, thanks a lot upstairs!!!
Old 03-12-2010, 06:46 AM
Ben Jenssen's Avatar
That's exactly what the mix knob was designed for.
And, moving the recorded region afterward should not be necessary. PT is smart enough to put the audio exactly where it's supposed to be. Compensating for the buffer delay.
F.ex, with a playback buffer at a certain size, the playback you hear has a certain amount of delay, so as you play along, you're actually playing a bit late. Bigger buffer: longer delay. PT automatically compensates for this and puts the audio a bit back.
You can check for yourself: record some audio, play it on your speakers and record it with a mic on a new track. Zoom in on the regions to check that they line up. PT should tackle this, whatever the buffer size.
(But we're talking VERY small amounts of delay here: f.ex 250 samples buffer = 5.6 milliseconds.)
Mbox mix knob always plays a drum track,Mbox 2 and Pro-tools LE 8: Haezel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-20-2011 02:58 AM
Mbox mini mix knob Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 05-18-2009 05:19 PM
Mbox 2 mini and mix knob Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-03-2009 04:20 PM
MBox 2 mix knob... pguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-10-2008 09:02 PM
Mbox and mix knob nick323 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-09-2003 11:05 AM
