  #91
Old 07-16-2014, 08:34 AM
dtonthept dtonthept is offline
Default Re: Need a new quieter fan to HD IO..
I put Silenx fans in both my HDIO 16 x 16 analogue and Omni over a year ago. They share a rack with a Mytek 8x192 and occasionally my Apogee Rosetta 800 gets switched on too. In other words, a lot of heat between them all.
I have the Omni at the bottom, HDIO above, then Mytek then Rosetta. There's clear rack spaces above and below each unit, and they've been working totally fine since I did the upgrade.
I got mine from Tiger Direct in Canada.
For the HDIO: Silenx IXP5211 iXtrema Pro Fan - 80mm x 15mm, 11dBA, 18CFM (S23-1010)
MPN: IXP5211
And for the Omni: Silenx IXP1114 iXtrema Pro Fan - 40mm x 10mm, 14dBA, 5CFM (S23-1000)
MPN: IXP1114
All up they came to $25 + tax + shipping + my install time but it's some of the best money I've ever spent in my studio.
Cheers,
D
  #92
Old 07-16-2014, 08:46 AM
propower propower is offline
To the poster above - I am glad things are working for you but the fan used in the 16X16 is 1/2 the CFM of the original. Not a great choice to my thinking.
http://www.gearslutz.com/board/geeks...8-digital.html
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
  #93
Old 07-16-2014, 12:01 PM
juhanni's Avatar
juhanni juhanni is offline
The efx-08-15.
can it push enough air for the 16x16?
The cfm are close to the original fan if I don't remember wrong..
-PT 12 HD
Mac pro 2x3,46 ghz 6-core
64 gb ram.
Pro tools HDX, Avid HD I/O 16x16 analog,
http://jonatanmusik.com/
  #94
Old 08-01-2014, 06:05 AM
Enzobar Enzobar is offline
Hi!
I replaced the stock fan with a Noctua NF-R8 PWM:
http://www.noctua.at/main.php?show=p...products_id=45
Everything works perfectly and the HD I/O 16x16 is almost inaudible:
10,2 dB / 1300 RPM / 39,4 CFM
  #95
Old 08-22-2014, 02:57 PM
Rectifried Rectifried is offline
Originally Posted by Meads View Post
In the HD IOs you don't need to splice the wires. The Silenx connector does fit the board.
It doesnt... silenex is smaller
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
  #96
Old 08-22-2014, 03:18 PM
Meads Meads is offline
Don't say "it doesn't", when it did.
Maybe you got a different fan.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
  #97
Old 09-09-2014, 08:25 AM
Peter Duemmler Peter Duemmler is offline
I changed my HD I/O fan to the SilenX 08-15. Connectors didn't fit, the first fan I got was broken from the start...
The second one works. It's so quiet it's scary. The cfm in the specs match the original fan, I hope that's true...
http://www.merlinsound.de
  #98
Old 11-07-2014, 01:34 AM
jacko's Avatar
jacko jacko is offline
Originally Posted by Enzobar View Post
Hi!
You should know that m3/h is not CFM. This fan has only 23CFM at 1300 RPM. Use this calculator to check: http://www.endmemo.com/sconvert/m3_hft3_min.php
You should consider running it at 1800RPM.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
  #99
Old 12-22-2014, 07:22 AM
jacko's Avatar
I did a simple video on how to replace the fan here: https://www.youtube.com/watch?v=UBaFzLtGG0Y
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #100
Old 01-13-2015, 02:55 PM
amazingrugs318 amazingrugs318 is offline
Changed my fan on my HD IO following these directions. A few steps differed, but it was enough to guide me through. Good luck! I've been loving the results...
http://www.pro-tools-expert.com/home...-or-hd-io.html
Mac Pro Cylinder 2013, Mavericks 10.9.4, 10 Core Intel Xeon E5 3.0 GHZ, 256GB Hard Drive, 32GB Ram
Pro Tools HD 11.2.1
HD Native PCIe and and UAD-2 Octo PCIe in Magma ExpressBox 3T
HD I/O 16x16 Analog
UAD Software 7.10
6GB Lacie 2Big Thunderbolt drive for Audio (set up in JBOD mode)
Is the Avid IO fan quieter than the 192 fan? Eric Lambert Pro Tools HDX & HD Native Systems (Mac) 84 02-22-2024 03:56 AM
Are the new HD 8x8 i/o's quieter than the last gen? guitarzzan Pro Tools 9 2 06-16-2011 10:52 PM
Quieter internal drive for new mac pro? bsmith23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-26-2009 04:48 AM
G4 quieter fan exchange Seller Pro Tools TDM Systems (Mac) 0 02-21-2003 08:53 PM
Which PC's are quieter? MGruschow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-03-2000 11:25 PM
