Old 03-15-2012, 07:56 AM
RoganX RoganX is offline
Default Audacity Sound, Reaper Sound, Pro Tools NO SOUND
I have the ASIO configuration setup in the control panel using input and output to the mbox. Works just fine with that setup in Reaper. With Audacity I don't see that ASIO control panel, but I do see its output to MME - which is different than Reaper - but never the less works.
I don't see any options in pro tool 10 so send sound to something other than the ASIO driver for the mbox.
I had a similar issue with Cubase and it was some button I had to enable. I've looked all over pro tools and I can't find the similar button.
The fact that reaper is using the mbox tells me pro tools should as well. I see signal levels in protools for recording and during playback - just no sound out of the speakers.
My cubase setup I no longer have and it was in Xp. My current setup is windows 7, pro tools 10 and mbox 1. I have a driver that works from
https://www.usb-audio.com/get-the-driver.asp and you can check out the demo here http://www.usb-audio.com/download.html...beep every 30 seconds. There is also asio4all driver - google asio4all - if you want to check it out.
Anyway is protools having a problem with the first gen mbox? Or is there some button like cubase I need to enable.
Old 03-15-2012, 08:21 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Audacity Sound, Reaper Sound, Pro Tools NO SOUND
Looks like it is.
http://duc.avid.com/showthread.php?t=318481
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 03-18-2012, 04:02 PM
Originally Posted by zedhed View Post
I have drivers that are developed for the mbox. It should work. ProTools 10 sees it. I also record into it and see audio, so playing back should be possible if it can receive audio. If it wasn't working I would imagine it wouldn't even record - buts its recording.
Old 03-18-2012, 10:06 PM
I got it to work using a asio4all beta driver. The version 10 did not playback and the usb asio driver from audio-usb.de didn't playback either. I had to an option that forces it to use 16bit, but I think that is fine for Vocals.
Mbox Pro 3 master volume knob initial adjust jumps from no sound to sound : | Focuret 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-17-2012 05:45 PM
MBox2Pro - Boot:No Sound; Disconnect/Reconnect Firewire: Get Sound; Why? mav9999 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-23-2009 09:48 PM
OT - PT / REAPER sound settings (and shortcuts) ChadB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-05-2009 08:51 AM
Skywalker Sound (Lucasfilm) Supervising Sound Editor Interview HDFilmtools Pro Tools TDM Systems (Mac) 0 10-02-2008 04:12 PM
Can't get Audacity sound through Digi 002R Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-08-2008 12:54 PM
