Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 09-20-2015, 10:39 PM
Josh523 Josh523 is offline
Default Structure LE users
Hi, how easy are the connections to setup with a workstation that would have same (connection) setup as a midi controller to use on Pro Tools 12? I see that at least they only are selling one version of it. Anyone used Structure with a Korg workstation? It has MIDI and USB. Do you use the MIDI connect to Mbox? It is for large sample libraries / organize drum kits
Old 09-30-2015, 04:59 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Structure LE users
I would say, as far as sample players are concerned, that Kontakt has it beat by light years.....
mapping is so easy in Kontakt.......
I do love some of my sounds that I had in structure....and it was once pretty darn cool, but it's been so many years now without updates that it is not really worth sinking your time into. IMHO
Daniel
When I loaded Structure from VIRT pack, Structure Free menu still there. dl0banter Virtual Instruments 2 06-12-2011 02:23 AM
The updater for Structure on Windows fails to locate and update Structure LE Top Jimmy Virtual Instruments 23 07-27-2010 08:40 PM
Structure Users - A.I.R. needs your Help! AIR Support Virtual Instruments 0 02-10-2009 03:37 AM
Structure Windows Users Needed chickensys Virtual Instruments 0 03-18-2008 02:33 PM
Structure Users filosofem Virtual Instruments 1 07-06-2007 08:25 PM
