Setting up output for playback
I'm new to Pro Tools and have managed to create a recording, but when I try to play it back, I don't hear anything. I'm assuming there is a way to set up the output for playback, but don't know how to. Can anyone provide some guidance??
Thanks! |
Re: Setting up output for playback
mcm15
filosofem
Aaron Mulqueen - 001 HD Native |
I'm using the MBox, connected to a Windows XP PC, and have created a single vocal track.
We're assuming here that you have everything set up correctly.
If you could detail how you have everything set up, cables, monitors, etc., etc., we could verify that everything is set up properly, stop assuming, and move away from the obvious.
mcm15
Here is a basic set-up Create a mono Audio track Create a Stereo Master fader Press Alt+K for Input Monitor Mode (...this gives you the ability to hear what you have recorded plus the ability to hear what you want to record at the same time) ...and monitor through your headphone jack or the output jacks on the back of your Mbox. Hope this helps. filosofem
Assuming your monitors are plugged in, have you turned the mix knob away from "input" so you can hear playback?
Thanks! I'm now able to hear the playback through the MBox headphone jack. Is there any way to get the playback to work through the speakers connected to my PC?
Why on earth would you want to do that?
To hear what it sounds like in a room environment without having to export the file.
You should be hooking up speakers to your mBox for that; it's what it is designed for.
If you must listen to the output through the PC speakers (NOT recommended for serious music making, BTW), you will have to hook up cables from the output of the mBox to the input of your soundcard. I want to stress again; it is highly recommended that you monitor the output of the mBox through a proper monitoring system; powered speakers, power amp and speakers; even a home stereo system would be better than most computer speaker systems.
PT10 - setting up input/output | jgiannis | Pro Tools 10 | 4 | 01-17-2014 05:21 PM |
Setting Output to -10dB - How? | Patill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-13-2011 07:41 PM |
setting up output | TAT6224 | Tips & Tricks | 9 | 09-28-2010 04:58 AM |
Re-setting output path | irvind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-29-2009 03:31 PM |
setting up Digi001 for audio output on OSX | Rob Keiter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-26-2004 03:29 PM |
