Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-24-2018, 08:02 AM
PaulTMA PaulTMA is offline
Default Re: How to set nudge settings to milliseconds in Pro Tools first?
This is what that link is supposed to say...
Defining the Nudge Value
The Nudge value determines how far clips and selections are moved when nudging.
Start and end points for selections can also be moved by the Nudge value (see Nudging Selection Start/End Points). In addition, clips can be trimmed by the Nudge value (see Trimming with Nudge).
To set the Nudge value:
Specify a Nudge value by doing one of the following:
From the Nudge value pop-up menu in the Edit window, select the Nudge value.
To specify a Nudge value not listed in the Nudge Value pop-up menu, click the Nudge Value indicator and type in the value.
Nudge Value pop-up menu showing milliseconds
To increase the nudge value incrementally:
Press Shift+Option+Equal (=) (Mac) or Shift+Alt+Equal (=) (Windows)
To decrease the nudge value incrementally:
Old 06-24-2018, 08:03 AM
Stig Eliassen's Avatar
Originally Posted by PaulTMA View Post
The above link appears to state that you can do so, but I can't see how to...
Search for "nudge" using that link you mention.
Old 06-24-2018, 08:04 AM
It may be this...
I'm not familiar with PT First, but can you change your main time ruler to Min:Secs, rather than Bars|Beats? If so, do the nudge values switch to increments of Min:Secs?
Old 06-24-2018, 10:42 AM
Try this, then see if the Nudge options change to values that are in Min:Secs rather than Bars|Beats. And sorry for the crappy pic.
BTW, it would probably help to take a look at the online help guide.
File Type: jpg Screen Shot 2018-06-24 at 1.38.57 PM.jpg (25.1 KB, 0 views)
Scott Gatteño
are 3 milliseconds of latency noticeable? jcche19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-25-2010 04:23 AM
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? EricHirsch ICON & C|24 1 08-13-2009 08:07 AM
Can't loop selections shorter then 500 milliseconds Brytbroder Pro Tools M-Powered (Win) 5 10-25-2007 01:48 PM
Milliseconds????? Peter Groom Pro Tools TDM Systems (Mac) 2 02-09-2007 06:14 AM
Midi Offset In Samples vs Milliseconds??? tomhartman Pro Tools TDM Systems (Mac) 2 07-05-2004 10:24 AM
