Old 03-24-2016, 02:55 AM
lightningad1 lightningad1 is offline
Default Renaming duplicated clips?
I urgently need to duplicate a huge heap of audio clips several times each, then rename each copy with a different unique name.
problem is when i rename one clip, every copy of the clip gets renamed...how can i duplicate clips then give them a unique name?
thanks
Adam
Old 03-24-2016, 05:08 AM
Led Led is offline
Default Re: Renaming duplicated clips?
Best workaround I can think of is select all clips, consolidate them (shift+alt+3)
then use strip silence (control+U) to separate them again, then you can rename them.
Old 03-24-2016, 05:15 AM
yeah - i found the only way was to consolidate each copy and then rename that such a pain!
Printing Fades Without Renaming Clips d_t macOS 7 11-26-2014 08:53 AM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
files from Mac to PC get duplicated with ._ crizdee Pro Tools TDM Systems (Mac) 2 12-07-2008 05:57 AM
