midi bug: cannot delete one note !
Hello,
I discovered a bug (I guess so): when I want to delete an event (a note in this case), nothing happens, it does not disappear. I delete (see the video included >>> VIDEO LINK), copy and delete the copy -this works well, but still not the original - edit works well also (velocity, volume .. .). I am on macos 10.13.3 and PT 2018.4 (installed since its release). I said that apart from that, no worries, and I am a "power user", I spend my days on my machine and it does not flinch (compo with audio and VI, and mix). I never had such a bug and that's the only one in my session (and never had that before)! An idea ? It's purely out of intellectual curiosity because I can do otherwise. Thank's By the way, my Pro Tools is in french (and so do I, sorry ) and "effacer" means "delete".
WIP house Prod - home studio iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61 STUDIO PRO Post-prod MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic. |
Re: midi bug: cannot delete one note !
It looks like the note might be spread across two clips. Can you try moving it so it is fully contained within one clip and see if it allows you to delete it?
I tried everything, moving (doesn’t work), cuting (doesn’t work), editing (doesn’t work). It’s like «*glued*» 🤪.
Have you tried in the edit window, notes view? Have you tried consolidating to a new clip, then try deleting the note?
edit window>note view = doesn't work
consolidate = not better Copying the clip on a new track = still not better. and also under the score editor. If I select a note, it becames blue, but not this specific one that stays black ! The only manipulation that works is to copy all the notes included in the clip except the one that has a problem, and create a new clip. Ghost note I should stop watching Stranger Things !
I have EXACTLY the same problem!
I have to Commit as Audio and chop it out - Not ideal! A |
Welcome in the twilligth zone
Comminting it, why not, but I want to be free to edit, I'm still under composing No, just copy and past the notes in a new clip (midi) without that one makes the job.
Could I send someone a link with just a midifile to see if the problem also occurs?
Midifile (yes, it's virus free !)
WIP house Prod - home studio iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61 STUDIO PRO Post-prod MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic. Last edited by PhiBee; 06-29-2018 at 03:13 AM. |
PhiBee:
Why not just delete the note from within the event list? |
Can you mute the note?
delete an earlier note | cuzzzzz | Getting Started | 0 | 10-26-2015 07:09 PM |
double click midi note add and delete | stevedresser83 | Windows | 1 | 05-06-2011 07:35 AM |
Smart Tool to delete midi note | protollo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 11-12-2009 12:39 AM |
can't delete a midi note !!?? | monkey | MIDI | 7 | 03-28-2003 05:12 PM |
