Old 02-17-2019, 08:40 AM
Default Re: Import audio… Beachball
Originally Posted by jwilkers View Post
I am back. I am having the same problem with my internal SSD. Therefore the spinners going to sleep could not be the issue. Anymore thoughts? Thank you!
Ouch.
Do you have anything else running while working in PT? Internet? Anti-virus? Wireless networking?
Jack
QAPLA!
Old 02-17-2019, 08:51 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi there also try with another playback device selected .
And be shure that your selecting all the time the importing audio selection and not the import data menu . This maybe sounds dumb and dont think would freeze PT but you never know .
Also it happens with the import menu only or dragging audio directly to PT timeline does it too ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 02-17-2019, 04:49 PM
jwilkers jwilkers is offline
Default
Internet? No
Anti-virus? No
Wireless networking? Yes for Pro Tools control on my dock.
Hi there also try with another playback device selected . Ok, I will.
And be sure that your selecting all the time the importing audio selection and not the import data menu. I am certain I am not doing this.
Also it happens with the import menu only or dragging audio directly to PT timeline does it too ? Never tried dragging. Drag to a track?
Old 02-17-2019, 05:30 PM
jeam25's Avatar
Yes
Protools Ultimate
Old 02-21-2019, 09:54 AM
OK, tried everything mentioned above. Same issue. HOWEVER, I did ONE drag to track which worked. But that's not to say that it wouldn't have worked the other way at that point in time. It is so hit and miss.......arg.
Anyway, if anything else comes to mind, throw it out there please and thanks for all of the suggestions.
If you think we've beat it to death, that's fine. It only costs a few minutes each time it happens and I don't import audio every day.
Just a bit of frustration.
  #16
Old 02-21-2019, 10:21 AM
jeam25's Avatar
Hi thinking about everything here , can you reinstall quicktime ?
The import menu is there to be working not to be broken . So it have to work right , with little will and patience with can help to get it working as intended .
Protools Ultimate
  #17
Old 02-22-2019, 05:15 AM
I can if you want. But Quicktime for vanilla pro tools? Does it even use that?
By the way, it happened again last night.
File-Import-Audio....clicked file....beachball...pro tools crash...no error.
I restarted pro tools and all worked fine.
By the way, I restart my computer every time I walk into my studio.
I leave it up over night for backups.
Which reminds me:
Carbon Copy Cloner and Clean My Mac are running in the background.
Wonder if I should shut them off.
  #18
Old 02-22-2019, 07:00 AM
jeam25's Avatar
Well your not supposed to have applications on background running cause this can cause conflict . Also check that you don't have other apps running too . You can check that in your system preferences > user login items .
Give a test without any running in background .
Protools Ultimate
  #19
Old 02-22-2019, 12:16 PM
Which reminds me:
Shut them off AND remove 'clean my Mac' aka 'destroy my Mac'. That utility is a disaster and is not to be trusted. There's no need to run CCC all the time.
Jack
QAPLA!
Cannot import audio track via Import Audio menu item vibeone macOS 14 12-13-2018 09:10 AM
Import audio files on one track using Import Audio Command Sir Hannes Pro Tools 12 6 01-16-2018 01:50 PM
PT 11.2 hangs (Mac beachball) on audio file import TomLewis Pro Tools 11 0 07-05-2014 04:16 PM
Importing audio takes FOREVER + beachball Dimak415 Pro Tools HDX & HD Native Systems (Mac) 2 10-19-2011 03:22 PM
Draggin audio from workspace = Beachball joji Pro Tools TDM Systems (Mac) 0 08-17-2010 07:35 PM
