Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 05-04-2006, 11:21 AM
LesPaul666 LesPaul666 is offline
Default Direct Monitoring in FW1814 and ProTools M Powered
I recently bought the 1814 and PT M-Powered 6.8r2 for my 1.67ghz Powerbook G4. I was wondering if with this setup if you can use the "Direct Monitoring" option on the M-Audio control panel mixer to use input monitoring, to avoid the latency in the ProTools software. It says in the manual that ProTools bypasses the inputs on the software mixer. Just curious, since I haven't been able to try it out myself, due to time constraints. Also, is it possible to monitor the inputs direct(including ADAT or SP/DIF?), while having a send on a particular input/track to an effect and monitor it back while recording?(unlike the Digi 001/002 in which the low-latency monitoring feature disables all sends). any input here would be appreciated, since I got this to be a really portable setup, to avoid using a mixer. Thanks.
MacBook Pro Penryn 15" (2.4 Core Duo 2) 4GB ram/200GB
OSX 10.5.5
PowerBook G4 1.67 15" Hi-Res 2GB ram/80GB(Oct 2005-The last model made)OSX 10.4.11
Pro Tools LE 7.3, 7.4, and 8
Pro Tools M-Powered 7.3, 7.4 and 8
Digi 003R
MBox Original USB
M-Audio ProFire Lightbridge
M-Audio Transit
(3) Metric Halo 2882's 2D +DSP
(1) Metric Halo ULN-2 3D +DSP
Old 05-04-2006, 04:29 PM
southboundloco's Avatar
southboundloco southboundloco is offline
Default Re: Direct Monitoring in FW1814 and ProTools M Pow
yes u can definitely monitor with zero latency with ur 1814...just mute the track ur recording onto in protools so that ur not listening to whats coming out of pro tools but ur listening to the input of ur 1814 before it goes into protools...just make sure u route ur 1814 input to one of ur output pairs(this is all done in the 1814 mixer window) just treat this window as a separate mixer where u can do routing before u go into pro tools...
Pro Tools 11.2
Pro Tools 10.3.9
REAPER
MPTK2
ProFire 2626
Benchmark DAC1
Neumann KH 120 A
Avid Artist Mix
ASUS Sabertooth Z77, Intel i7-3770K CPU OC'd@4.7GHz, 32 Gigs RAM
Mac OS X 10.9.3 Mavericks
Old 05-04-2006, 05:10 PM
Thanks very much, any idea if there's a way to use the SP/DIF output and input to use say, a Lexicon MX200 effect processor in the loop to listen to an effect while recording with no latency? Thanks again
OSX 10.5.5
Digi 003R
MBox Original USB
M-Audio Transit
Old 05-05-2006, 04:45 PM
chris110000100101001 chris110000100101001 is offline
Such as reverb in a singers cans?
Hook up your lexi via the s/pdif i/o
Send from vox track to s/pdif out (pre fader)
Bus the signal out from the lexi (s/pdif inputs) straight to the cans from within the m-audio control panel.
Latency won't matter with verb/delay based effects
SMPTE for the devil
Old 05-06-2006, 09:45 PM
fhinspectit fhinspectit is offline
will there be a latency problem if the analog i/o where used? delta 44
Old 05-07-2006, 11:04 PM
Anytime you monitor through software there will be some latency. It usually isn't much of a problem for something like reverb in a cue mix, as the latency will just sound like pre-delay.
Another way would be to route the input of the vocal to another output on the maudio control panel and connect the reverb to it. then bring the reverb back to a spare input and route that out to the cans. - no latency, but in my case more f**ing around.
chris
SMPTE for the devil
Direct Monitoring on MAC carbarnrob Pro Tools 10 0 10-24-2011 11:18 AM
Win XP Sp3 + M-Powered 7.4 + FW1814 = What drivers? Finnish Pro Tools M-Powered (Win) 1 02-22-2011 07:30 AM
FW1814 clicks only with ProTools not other app's joeR Pro Tools M-Powered (Win) 0 09-18-2006 05:00 PM
M-Powered 7.0 + FW1814 MTC timeout? alexkbd Pro Tools M-Powered (Win) 3 01-09-2006 09:37 AM
FW1814 doesn't work with M-Powered! Aleatoric Pro Tools M-Powered (Mac) 5 05-13-2005 07:29 AM
