Old 01-15-2013, 03:23 AM
Balta Balta is offline
Default D.Show Sidecar malfunction
Hi
I have a strange issue with the sidecar of our D-Show. with one of our FOH Racks it starts normally with the other rack remains in stand-by mode and it´s not recognized by the system.
Evry Help Welcome
Old 01-15-2013, 12:25 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: D.Show Sidecar malfunction
If the only thing that changes between systems is the FOH Rack then that's the place to focus. This assumes the FOH Link cable is the same, and the D-SHow Main unit is the same.
Start by checking all cables inside the FOH Rack, including those connecting the local IO cards to the DSP engine cards. Reseat these connections, and see if that helps. If not, the problem may be on the umbilical card that contains the big multi pin FOH Link connector.
Check the FOH Link connector and cable, to ensure there are no bent/missing pins or contacts. If that checks out ok, there may be a connection loose on the umbilical card itself. This is a more involved procedure, so you should contact either your local VENUE service/support center for assistance, or the Avid support team: venuesupport(at)avid(dot)com.
Sheldon
Old 01-16-2013, 08:09 AM
Hi Sheldon
Thank for your help.
I am also in contact with the support that give me the same directions and send me a few instructions to try.
I post the results soon as possible.
Balta
João Baltazar
Sound Engineer
Puro Audio / Puro Mix
Portugal / Angola
Old 04-01-2019, 08:42 AM
john youker john youker is offline
Hey guys,
I have a bad Umbilical cable. The folks who are repairing it need help in taking it apart. It is Avid Part No. 9940-31606-00.
Thanks for any help.
John Youker
Old 04-08-2019, 02:21 AM
Kristo Kotkas Kristo Kotkas is offline
Originally Posted by john youker View Post
Hey guys,
John Youker
Not sure if it is a serviceable cable, of course anything could be repaired in theory but I don't think this one is officially reparable. You can always discuss this with Live Sound support
Venue Sidecar - No Power crazy_urn VENUE Live Sound Systems 2 05-23-2013 11:54 AM
Audio malfunction/midi malfunction Atomicroaddaddy macOS 1 10-10-2012 05:59 AM
Pro Tools/D-Show standalone integration idea with D-Show show files/virt. soundcheck digidesigner VENUE Live Sound Systems 2 11-08-2011 02:52 PM
Sidecar--9 Faders??? Scott Fahy VENUE Live Sound Systems 1 11-30-2007 10:57 AM
Sidecar on the right question oldzguy VENUE Live Sound Systems 7 09-29-2006 10:15 PM
