Old 01-14-2008, 02:54 PM
bobtastic bobtastic is offline
Default Is it possible to use a Motu 8Pre with ProTools?
Hi all,
I'm running an MBox 1 with ProTools LE 7, and i've acquired a Motu 8Pre Firewire Audio interface.
Does anyone know if it is possible to run the Motu along side the MBox to get 8 extra extra inputs in ProTools?
Thanks in advance.
Old 01-14-2008, 02:57 PM
spkguitar's Avatar
Default Re: Is it possible to use a Motu 8Pre with ProTools?
No. It is not possible. All audio I/O with Pro Tools must pass through a piece of Digidesign hardware.
Old 01-14-2008, 02:59 PM
spkguitar's Avatar
If you were using one of the 00 series (002, 003, 002R, 003R, 001) you would be able to use it connected via ADAT optical for 8 more channels.
Old 01-14-2008, 03:01 PM
Ah shame didn't think so, i know you can use via ADAT on some of the higher range gear but i suppose the MBox is a little too budget.
Thanks anyway
Old 01-14-2008, 09:37 PM
akakpaws akakpaws is offline
In the case with a lightpipe ADAT connection between an 002R and a Motu 828 mkII, would the 828 I/O's appear and be available in the I/O section of PTLE?
Old 01-14-2008, 10:49 PM
spkguitar's Avatar
Technically, yes. The lightpipe I/O is always available in in the I/O section of PTLE when using one of the 00 hardware units (as long as the I/O setup has been defaulted for the 00 unit connected). It doesn't really matter what's connected to it. If a lightpipe unit (such as the MOTU) is connected to it and can function in standalone mode (meaning without otherwise being connected to the computer), then those I/O are available to use.
MOTU 8pre Dvargas Pro Tools 9 9 03-15-2012 12:16 PM
MOTU 8PRE via Optical alpethtel@yahoo.com 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-28-2009 03:17 PM
Using MOTU 8pre with 002 hutchypie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-10-2008 05:28 PM
Motu 8pre to 002 via ADAT?? Help! linchpinc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-18-2007 07:42 AM
Motu 8pre to 002 via ADAT?? Help! linchpinc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-18-2007 04:26 AM
