Old 05-30-2018, 08:36 AM
Falconwas Falconwas is offline
Default PT HD 11 & 12 on same build?
I'm thinking of installing Pro Tools HD 11.3.2 and 12.4 on the same build - Yosemite 10.10.4. Any caveats with this? Which HD driver do I use? 11.3.2 or 12.4?
Thanks in advance!
Falcon
Old 05-31-2018, 12:21 PM
Question Re: PT HD 11 & 12 on same build?
This is not a supported configuration. When you launch either version, it will overwrite the plug-ins that were installed by the previously launched version. Related to your question, the drivers are different.
Why do you want to do this? That may lead us down the path where you only need a single version.
If you really do need to do this, the best way is to have two bootable volumes, each with its own PT HD install.
New Build Review! Based on Mano/Ame? and SPCR Fanless build Calipoop Windows 4 11-16-2011 09:38 PM
PT just does not work, so should I build a new PC build or just but a MAC? ajcsound Windows 17 05-17-2011 10:22 PM
To build or not to build? Money is the question... storm-01 Tips & Tricks 5 09-23-2003 01:08 PM
To build or not to build? Money is the question... storm-01 Pro Tools TDM Systems (Mac) 12 09-19-2003 07:40 PM
To build or not to build? Money is the question... storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-18-2003 09:13 PM
