Old 09-26-2017, 11:24 AM
Slamuel Slamuel is offline
Default Bleed inside of Pro Tools 11 when hard panning
I'm trying to put one region on the left track and another on the right track of a stereo mix but when the left ear gets to a soft part I can hear bleed from the right clear as day. I've tried using a single stereo track, two mono tracks hard panned, bouncing each out as mono and then re-importing, creating two mono master faders and assigning one to the left and the other to the right but nothing works. I'm using my built in output straight to my headphones.
Could this be a hardware issue with my laptop? I'm just at a loss because I didn't think cross-talk could happen inside of a DAW and I'm getting this issue before I bounce the tracks out (and after too). I have searched for threads on this topic already but nothing has worked. Any suggestions?
Old 09-26-2017, 06:19 PM
Drew Mazurek's Avatar
Default Re: Bleed inside of Pro Tools 11 when hard panning
Originally Posted by Slamuel View Post
Do you have a "widener" on the master fader? Or something like Slate VCC?
You say you can hear it plain as day, but what do the meters and waveforms of the render file look like?
www.drewmazurek.com
Old 09-26-2017, 08:19 PM
And headphones...
Old 09-27-2017, 05:31 AM
Originally Posted by Darryl Ramm View Post
And headphones...
Unless the headphone amp has a cross-feed function you shouldn't get channel bleed.
Jack
QAPLA!
Old 09-27-2017, 09:03 AM
Could this be a hardware issue with my laptop?...
Yes.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 09-27-2017, 10:56 AM
Originally Posted by Rich Breen View Post
Yes.
He's on a MBP going direct to his cans and I have to wonder why he's not using the headphone output on his MBox III. To the best of my knowledge I don't believe either has a crossfeed function and neither do those Shure cans he's using. A thought does come to mind and that is with using both sets of I/O at the same time he's got to be using aggregate I/O and maybe that's the problem?
Jack
QAPLA!
Old 09-27-2017, 11:25 AM
I think Rich is saying that that crappy headphone amp could have unintentional crosstalk.
www.drewmazurek.com
bleed over when hard panning peaveyfan Pro Tools 10 14 06-09-2015 05:28 AM
Panning bleed/crosstalk issues inside of Pro Tools friggindrummer macOS 14 08-21-2013 01:15 PM
PT9 bug: Hard panning reopening centered tclash macOS 0 06-07-2011 09:15 PM
Hard Panning Issues in PT LE linderefter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-13-2011 09:31 PM
HELP! Hard Panning bleed krop015 Pro Tools TDM Systems (Mac) 3 08-25-2010 01:29 AM
