Old 09-16-2017, 10:24 AM
joshfrog94 joshfrog94 is offline
Default Can't copy and paste in Pro Tools 11
Please help me. I have tried right clicking copy and paste and going to the edit window and clicking copy then going to the other audio track, setting the place on the timeline, and using the edit window to choose paste. I get nothing.
I tried to work around by making a new audio track and duplicating, but I could not grab and move the duplicate audio down to the desired track. I suspect I need to change a setting. Thanks in advance for your patience and help.
Old 09-17-2017, 05:18 AM
Default Re: Can't copy and paste in Pro Tools 11
Your wording is a bit confusing.
You need a basic understanding of computer copy & paste. You select the audio you want to copy in a track in the Edit screen then you right click to copy the audio. Go to the target track, click on the timeline where you want to paste the audio and then either paste or merge the audio into the new track at the point in time you want it. Make sure you also have the track selected in the left-hand part of the track.
Look in your PT Reference Guide (aka The Manual) for the difference between paste and merge.
Jack
QAPLA!
Old 09-20-2017, 12:20 PM
I do have a basic understanding of computer copy and paste. I mentioned using both right click copy and paste of the highlighted track, then, with timeline in appropriate place, tried to right click and paste on another track and nothing happened. There is an undo paste in the edit menu, no track pasted in the other audio track.
Same result using the edit dropdown menu. I have the tempo correct;y identified.
Old 09-20-2017, 01:05 PM
Make sure the track you want to copy to is selected (the track name is highlighted). Also make sure you're trying to copy to a like track - mono audio to mono audio, stereo audio to stereo audio, MIDI to MIDI (or an instrument track) etc. Also try merge. What you're trying to do is basic PT usage.
Jack
QAPLA!
Pro Tools 12.5 Midi Note Copy Paste donalddeana Pro Tools 12 5 06-13-2016 05:40 PM
Automation Copy Paste Broke in Pro Tools 10.2 chuckgreenjr Pro Tools 10 2 08-27-2012 07:31 PM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 02:19 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 01:46 AM
Bug Report - Pro Tools 7.3.x - Copy/Paste to Grid innacurate HDUser13 Pro Tools TDM Systems (Mac) 4 10-04-2007 03:34 PM
