Old 09-06-2017, 05:40 PM
Squirejmaguire Squirejmaguire is offline
Default ProTools 11 insufficient user privileges
I recently raised an insufficient user privileges issue with the avid help desk.
I have been advised that this can only be resolved if I purchase a Product Support Code costing $39..
Can this be right? Do I have to pay to have this fixed.
I phoned Avid UK directly.I only reached voicemail and received no response to my message
Old 09-06-2017, 05:50 PM
Default Re: ProTools 11 insufficient user privileges
Well you could always just try Googling the exact error message you got and you would find information about setting the Pro Tools application to run as administrator and that would probably fix the issue.
But if you don't want to do that, and especially since you probably got here by not following the Pro Tools software install documentation, then sure Avid charging you for their time to help you with a problem you created seems pretty reasonable.
If that is not it, start at the "help us help you" link up the top of each DUC web page, and provide more info, or buy that ASC.
Old 09-06-2017, 06:02 PM
Hey Darryl,
Thanks for the reply..
I've tried all the Google options to no avail..
But I shall persevere,but I will not be buying the ASC which only lasts 60 days anyway..
Old 09-06-2017, 06:22 PM
Originally Posted by Squirejmaguire View Post
Hey Darryl,
You have googled for the error message and found the instructions and tired it and nothing happened? You have the Pro Tools app set to run as administrator? (not you being administrator when you launch it, that is different).
You need to explain exactly what you are doing on what system, what software etc.
Old 09-07-2017, 05:55 AM
Putting on my Great Karnak costume I deduce that the error message the op posted is from a Windows system. As Darryl said op needs to run as admin. Also make sure the iLok is plugged into a working USB port and that all power savings measures for those ports are turned off in Windows Control Panel.
Of course more complete system info (actually any system info) would lead to a better diagnosis. I can never understand why people waste time when they don't post system specs or have them in their profile page. Super simple and the problem gets solved quicker with better advice.
Jack
QAPLA!
Insufficient Privileges to start Low Level Driver Cimond Pro Tools 10 8 01-10-2019 03:17 PM
Initialization Error: User privileges insufficient to start low level driver JULIN General Discussion 1 08-28-2014 09:01 PM
Insufficient access privileges - Protools 6.4 LE Bond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-17-2006 12:07 AM
ProTools LE 6.9.2 user accounts and privileges fful@conncoll.edu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-20-2006 09:30 PM
Insufficient access privileges warning??? logicaltextures Pro Tools TDM Systems (Mac) 2 01-03-2004 05:21 PM
