A problem with PT E on Snow Leopard
Hi there,
I'm using a 13" Macbook Pro, SnowLeopard 10.6.2. Initially I had the same problem as other users: The Installation Failed The installer encountered an error that caused the installer to fail. Contact software manufacturer for details When I tried to install 8.0.3, the same thing appeared. I have used the InterLok installer. However, the PT icon appeared on my dock, and I am able to open the program now, however it is different: the first example I can give is that when I open the program, there is no option to choose from Templates. I feel that the installation has not been fully successful. Is there anything else I can do to achieve this? |
Re: A problem with PT E on Snow Leopard
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
I was going from the tutorial video on M-Audio's web site, which runs through using PT Essential for Fast Track recorders.
http://www.m-audio.com/index.php?do=...cdfa5fb646699b |
I would contact digi at this point assuming your dvd may be bad. If you registered they will probably put a download version in your account so you can download and install with that instead of the dvd.
I ran into the same installation problem on a new Macbook Pro last night. The DVD made it about 90% through, gave a message saying there was about a minute remaining and then hung. It made noises every once in a while, but never completed. I couldn't quit the installation either. I hard powered off with the on off button and downloaded 8.0.3, following the online instructions to use the downloaded installer with the 8.0.2 disk installed.
I think we both made the same mistake by trying to load 8.0.2 on 10.6.2 to begin with. Mine is working fine so far. Maybe you could select uninstall from the download and start over, using the 8.0.3 download with the 8.0.2 disk sitting in the drive just for verification or whatever it uses it for. bilco |
PT 10.3.3 + Snow Leopard 10.6.8 hotkey problem | JamieRobb | macOS | 2 | 01-04-2013 05:10 AM |
Problem detected with audio clock etc...PT10 and Mbox2, Snow Leopard. | YouMeOh | macOS | 5 | 02-10-2012 12:30 PM |
Problem with Pro Tools 8.0.5 and Snow Leopard 10.6.8 | greghorne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 10-29-2011 02:10 PM |
Mbox 2 mini Snow Leopard(10.6.3) problem | anti_75 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-21-2010 10:26 PM |
MBox2 Mini Problem on Snow Leopard OSX 10.6.3 | elcw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-31-2010 11:02 AM |
