Re: Track Presets in Pro Tools 10
STILL NO TRACK PRESET.
c:\ DOCUMENTS\AVID\TRACK PRESETS\VOX\VOX.PTXT (Sub Folder) It saves it as session file not a track preset VERY FRUSTRATING THIS IS IN PRO TOOLS 10.3.7 |
Oops, sorry to hear this. I am on Mac and PT 11 so.... unfortunately cannot help here I guess.
Thanks Oliver
Guess what !!!! It works in PT11 Thanks mate. So what you posted was correct. Track Presets "Plural" However I will persist with PT10.3.7 You're a legend Again many thanks |
I assume you used the "Save As Template..." feature, have you tried "Export/Selected Tracks as New Session…" in PT 10? You then must change the extension from "ptx" to "ptxt" manually. |
Hi Oliver
Sorry about the delay response. Being on the other side of the world here in Australia. And yes in Pt 11, I did use " Save as Template" I will give your sugestion a go in PT10. Tonight OZ Time. I will keep you posted. Track Presets Fantastic |
#16
Just to clarify
this "hack" can also be applied in protools 8 og 9 ""If you are on 8 or 9, then here’s how to do it… 1) Go to Applications > Avid > Pro Tools (or Digidesign > Pro Tools for v8 or 9). Here, create a folder titled “Track Presets”. I also recommend creating folders within “Track Presets” for different categories (ex: Submix Masters, Reverbs, etc) although you can do that later on. 2) Create and configure tracks (including inputs, outputs, names, sends, volume, pan, plug-ins, etc) as desired. 3) From the File menu, choose Save As Template. 4) Choose “Select Location for template” 5) Navigate to a folder within the Track Presets folder (or create a new folder in Track Presets) or just save anywhere then move the template(s) to these folders later. Once your templates are saved to folders within the “Track Presets” folder, they will appear as options in the New Track dialog below the normal track types (audio track, aux input track, etc). You can still use Command + Down/Up to switch through these and Option Command Down/Up will switch between multiples in your sub-folders. by Russ Hughes" i can make this work ,but i need to restart protools before it takes affect dont know if this is old news
Brian Uller Denmark |
#17
for me, it's working on PT10 but not PT11. Not sure why but if someone can guide me thru this it would be great.
I'm on Mac PTHD11 native thunderbolt. Thanks |
#18
What exactly do you mean it's not working for you? You can't create them or you can create them but PT11 doesn't see them? The track presets folder for PT11 on a Mac is in a folder off your Mac username home folder.
#19
Musicman691 thanks for your help, I was in the PT10 folder. Had to go to my username folder. Thanks again bro.
#20
No problem; it confused me at first as well.
Track Presets | Kenny Gioia | Tips & Tricks | 30 | 01-31-2014 04:33 PM |
Track presets in 11? | albee1952 | Pro Tools 11 | 2 | 06-24-2013 04:37 PM |
Track Presets!!! | albee1952 | Pro Tools 10 | 8 | 12-29-2012 08:13 PM |
Track/"Channel Strip" Presets DO exist in Pro Tools, apparently... | PTPhillip | Pro Tools 10 | 97 | 10-20-2012 01:03 AM |
Track presets in PT??? | dgkenney | Pro Tools TDM Systems (Win) | 3 | 12-22-2009 10:03 AM |
