Old 07-26-2002, 02:54 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac
for Pro Tools|HD for Macintosh Systems
Is now available from the Support/Downloads section in the following location:
http://www.digidesign.com/download/cs/531r2/
In order to use Pro Tools 5.3.1r2, you must first run the Pro Tools 5.3.1 installer, either from the Pro Tools 5.3.1 CD or the Pro Tools 5.3.1 download.
What's Fixed in Pro Tools 5.3.1r2?
This version contains fixes for the following problems found in Pro Tools TDM 5.3.1 for Macintosh:
  • <font size="2" face="Verdana, Arial">Assorted issues when using PRE in conjunction with ProControl & Control|24
  • <font size="2" face="Verdana, Arial">The Feet.Frames ruler was incorrectly calculated when session frame rate was set to 29.97
  • <font size="2" face="Verdana, Arial">Inserting silence into a MIDI track did not always displace automation data accordingly
  • <font size="2" face="Verdana, Arial">DirectConnect plug-ins or applications like Soft SampleCell and Native Instruments did not work with the 192 Digital I/O
<font size="2" face="Verdana, Arial">Who Should Use Pro Tools TDM 5.3.1r2?
This release has been fully qualified by Digidesign, and should be used by all Pro Tools|HD users on Macintosh-based systems, though if you do not use PRE, MIDI tracks, 192 Digital I/O or the Feet.Frames ruler, you will gain no advantage by updating from version 5.3.1.
Regards,
Digi Pro Tools Team
Administrator
Old 07-26-2002, 03:52 PM
michael c michael c is offline
Default Re: Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac
Is there a DigiStream version that has the lower "128" buffer for Direct Connect for this update? That is important!
Mac Pro 3.5GHz 6-core (6.1 2015)
Monterey 12.6.8
64 GB RAM
1 TB PCIe flash storage
Pro Tools Ultimate HD 2023.6
HD Native Thunderbolt
Old 07-26-2002, 06:22 PM
Avid's Avatar
Administrator
There is not one yet, but we are working on it.
The Digidesign StreamManager included with 5.3.1r2 is the regular 512 sample buffer version. Although it will work with all Pro Tools 5.3.1 systems, it is a specific fix for users experiencing the following problem:
If you do not have a 192 Digital I/O, but want to use the 128 sample buffer version, you should continue using the same Digidesign StreamManager_128 version in the Beta folder on the 5.3 and 5.3.1 Pro Tools CD.
As soon as we have a version of the Digidesign StreamManager_128 with the fix for 192 Digital I/O owners, we will post it in the Downloads section and let you know on the DUC. We're working on it now and expect to post it next week.
Administrator
Old 07-26-2002, 09:24 PM
Thanks for the info. Definitely need a 128 version. (How 'bout a 32 version!)
BTW, I used 5.3.1, 192 I/O with SoftSample Cell and had no problems. What does the 192 I/O have to do w/SoftSample Cell?
Monterey 12.6.8
64 GB RAM
Old 07-27-2002, 01:19 AM
Avid's Avatar
Administrator
<font size="2" face="Verdana, Arial">No problem there. The problem only ocurred when using the 192 Digital I/O and DirectConnect applications.
Administrator
Old 07-27-2002, 11:38 AM
AndiB AndiB is offline
Does this release include the beat detective bug fix?
Old 07-27-2002, 11:42 AM
Just wanted to let you know that I have been using Soft SampleCell w/Direct Connect in 5.3.1 w/ no problem w/ 192 I/O. Haven't tried the Native Instruments apps yet.
Monterey 12.6.8
64 GB RAM
Old 07-27-2002, 04:07 PM
dragsquares dragsquares is offline
I've been having this problem with my "plain" 192 i/o (with an added 8 inputs). Does the update address that as well? Time to download and find out...
Old 07-28-2002, 12:11 AM
lagasus lagasus is offline
<font size="2" face="Verdana, Arial">The problem tht was fixed was with the 192 DIGITAL I/O, not the 192 I/O; they are two different products.
Old 07-29-2002, 09:11 AM
Mick F. Cantarella Mick F. Cantarella is offline
Might there be any complications with plug in authorizations with this update? Thanks, -Mick
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid ProControl, Control|24, Command|8 3 07-29-2002 10:32 AM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid Tips & Tricks 7 07-27-2002 04:58 PM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid ICON & C|24 0 07-26-2002 03:14 PM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid Post - Surround - Video 0 07-26-2002 03:00 PM
Pro Tools 5.3.1r2 Update for Pro Tools|HD Mac Avid General 0 07-26-2002 02:52 PM
