Old 05-04-2020, 07:35 AM
midigame midigame is offline
Default Roland Sound Modules
Hi,I hope someone can help with this query.I have used Sonar Professional for some years but now I am giving Pro Tools First a trial.I have two Roland sound modules a JV 2080 and an Integra 7.All the instrument sounds are listed for the JV 2080 but none are listed for the Integra 7.Has anyone any idea how I can use the Integra 7 in Pro Tools.
regards
midigame
Old 05-04-2020, 11:40 AM
Default Re: Roland Sound Modules
You could always go the old fashioned way and manually set the sounds on the Integra 7. Or do a bank select/patch select on a MIDI or Instrument track as part of the outgoing MIDI stream. You just won't have the luxury of seeing the patch names that's selected on the Integra.
Jack
QAPLA!
Old 05-04-2020, 03:30 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
See if this helps:
Integra-7 midnam creation for Pro Tools
Could be a long project to get all 6000 sounds.
Some of the Integra-7 midi patch names will be in the Roland XV-5080.midnam file, although from what some looking around the web suggests that not all parameters for the Integra-7 would be included in the same patch names for the XV-5080.
Your Pro Tools MIDI Patch Names can be found here, and this is where you would place a new patch name file:
On my Mac, that would be located here:
/Library/Audio/MIDI Patch Names/Avid/Roland
On your Win machine, I think it would be here:
C:\Program Files\Common Files\Avid\Pro Tools\MIDI Patch Names\Digidesign\Roland
Bruce Paine
System Details
Old 05-08-2020, 03:00 AM
Thanks for the advice guys.I'm afraid my level of expertise does'nt go much beyond opening dropdown lists.Although I did try to open the link to the midnam file that Bruce provided,but it tells me that it is not there anymore.I wonder if,perhaps you could post it again Bruce?
Once again thanks for your help,I appreciate it.
best regards
Adrian
PT9 + sound modules? Oroz Pro Tools 9 0 11-29-2010 09:16 PM
Sound modules too low into 192 aztlan2010 Pro Tools TDM Systems (Mac) 20 05-27-2009 03:59 PM
xBox as sound modules?? CraigLearmont Pro Tools TDM Systems (Win) 0 01-12-2004 10:01 AM
Midi sound Modules!! what do you use? Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 08-02-2002 09:43 AM
GigaSampler, Sound Modules and us... Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 02-17-2002 12:25 AM
