Re: Buying old version of PT?
Got it.
So the dividing line goes when PT moved from DigiDesign brand (up to PT8) to Avid brand (PT9 and later). DigiDesign licenses are freely transferable, but Avid licenses need pre-approval. Which means if you want to legally buy and sell PT9 and later licenses, you must go through Avid's Transfer of Ownership process. Whether or not it requires active Support and Update Plan for PT9 when such plan was not available at the time, that I do not know. But until Avid approves your transfer, iLok will not be able to do it.
That helps, thanks. I found a couple of official German shops that sell new and unactivated PT9 keys with full warranty. I'll look into the requirements by Avid before considering that.
If it is unregistered and unused code, it should work as you would be the original owner
Keep in mind that PT 9 and 10 is not compatible w/windows10. You need to run W7.
#16
Short update in case anyone cares: digi002 console is working perfectly with PT10. Only my old Waves installer was not compatible with PT10 and give loads of errors. I bought Diamond bundle on the latest Waves for PT10.3 (Waves 9.6) and got the SSL G eq for free too, working perfectly.
#17
So did you find PT10 somewhere or bought PT9 and then reinstated Support and Update Plan and therefore now have a current license?
Buying an older version of "Structure" license or software | Healtone | Licensing & Accounts | 1 | 06-28-2016 08:41 AM |
Check the box before buying Fast Track Version of PT Essential! | bilco | Pro Tools SE and Essential (Mac) | 14 | 02-09-2010 05:50 PM |
Buying an Academic version | grzaudio | Pro Tools M-Powered (Mac) | 1 | 01-20-2010 08:07 AM |
Buying protools 7,4, which version do i need to buy? | thinksamuel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-02-2008 07:25 AM |
HELP! I am buying a Dell Laptop with intent on buying a DIGI 001 as well | xian$ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-18-2003 11:53 AM |
