Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 05-19-2015, 03:19 PM
Rosco1969 Rosco1969 is offline
Default Apollo 8 and Apollo Twin
Hi all,
My question is this:
If I buy an Apollo 8 (previous gen) with both firewire connection and thunderbolt so that I can use my older Macbook Pro via firewire... Am I then able to, for example, connect the Apollo 8 to the MacBook Pro via firewire, then add my Apollo Twin into the chain using the Thunderbolt connection? will this work? Will the system recognise all the devices the same way just as if it had been done exclusively with Thunderbolt?
Anyone have any experience of this kinda setup?
Thanks
Rosco
Old 05-19-2015, 03:46 PM
Nope. The Apollo (or anything else) cannot convert from Firewire to Thunderbolt (going the other way is trivial), besides an Apollo is either running as a Thunderbolt *or* Firewire interface.
Old 05-21-2015, 10:52 AM
Default
Ok, so, if you use the Firewire port on the Apollo, the thunderbolt ports are then dormant, i.e they do nothing? I'm not trying to convert anything, I just wondered if the Apollo Twin would be recognised if it was connected to the Apollo thunderbolt port.
Old 05-21-2015, 01:05 PM
Default
You *are* asking to convert from Firewire to Thunderbolt. It is the software on your computer that does the "recognition" or aggregation here, you need your computer to talk thorough the Firewire interface to the Thunderbolt interface on another Apollo, which as I explained it can't as a Firewire interface can't convert from Firewire to Thunderbolt.
And yes even if that was possible, the Apollos talks either Firewire or Thunderbolt, both ports are not active.
Next question...
Old 05-21-2015, 04:24 PM
Default
Why is the sky blue?
Old 05-22-2015, 05:31 AM
JoelG's Avatar
JoelG JoelG is offline
Default
http://spaceplace.nasa.gov/blue-sky/en/
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 05-22-2015, 07:53 AM
Default
Originally Posted by JoelG View Post
Oooooft!
UAD Apollo Twin as Standalone DSP with PT HD? outoftune Pro Tools HDX & HD Native Systems (Mac) 23 12-04-2015 08:39 AM
No Signal from UA Apollo Twin fpalmieri macOS 21 05-07-2015 09:52 PM
UAD Apollo Twin question... Rosco1969 FireWire & USB Audio Interfaces (Mac) 5 09-23-2014 01:07 PM
PT 11 HD on Macbook w UA Apollo Twin? jacknprewitt Pro Tools 11 3 06-07-2014 08:49 AM
New UA Apollo Twin nst7 Third Party Interfaces 0 01-23-2014 09:52 PM
