Soft Key Programming issue
All,
I am trying to set up a series of softkeys to do some repetitive tasks that I face on a daily basis. 1.) I want to capture the name of a video clip, move 10seconds down the time line (all of my videos have 10 sec of leader) create a marker and paste in the name. 2.) capture the name of a video clip, select bounce to quicktime, tab down to the name field, paste the name, remove the last 16 characters from the name. 3.) Similar to 2, but bounce to file instead of quicktime. I can program most of this in. I can select the region (CNTR - TAB), rename the region (Shift ALT R) and copy the name. After this point the automating gets inconsistent. It will usually hang at the rename window. Adding pauses seems to help, but it will usually try to add new markers without actually copying the name. Is there an easier way of doing this? If not, what am i not doing that would enable this to work better?
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
Re: Soft Key Programming issue
You may need to add a lot more pauses into your macro. Lots of times it is doing everything right but it does them too quickly, before the computer can respond.
I have similar macros to these and tons more. I use Keybord Maestro which is an awesome tool built specifically for this type of stuff. It is much quicker to program macros and debug them to get them working just right. They can easily be backed up or shared with multiple mahines. I would highly suggest looking into that app if you want to dive deeper into macros and keystroke automation. The eucon ones are great for quickly accessing your favorite functions or for grouping together toggling groups of a few commands, but for extended macros it is difficult to quickly create them get consistent results.
Dan Smith Re-Recording Mixer - Warner Brothers |
Thank you Dan,
I Will look into keyboard maestro. Quote:
I also use Keyboard Maestro for exactly this purpose. Much better than trying to do it all with Eucon. And it can do incredibly complex tasks if you want. But even if you just want macros it's worth it.
~Will |
Custom Soft Key Issue with 5ms Delay | vicviper | Avid S4/S6 | 2 | 04-03-2015 01:29 PM |
Programming CTRL/ALT as Soft Keys | djblitz | Artist Series | 4 | 04-30-2013 11:42 AM |
Boom programming issue | MotifMan | Virtual Instruments | 7 | 03-13-2010 01:17 PM |
D-Control Soft Key Playlist Button Issue | GlennR01 | ICON & C|24 | 2 | 09-28-2008 07:48 PM |
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? | rtcstudio | Pro Tools TDM Systems (Mac) | 3 | 11-16-2002 07:57 PM |
