#21
Re: LtRt AAX plugin
I have Dolby Surround Tools as a TDM for sale in the classifieds which I believe does 4-2-4 encode-decode. Open for offers...
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
#22
Re: LtRt AAX plugin
I got to our local Dolby consultant and he told me, that it is possible with the Dolby Atmos Production Suite. I have to check out the workflow to see if it's feasible.
If it works, it's the cheapest LtRt and other formats encoder/decoder on the planet Cheers Maik
PT HDN 2023.6, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.6.6, BM Decklink Extreme 3D ------------ mars13.de |
#23
Re: LtRt AAX plugin
If it's feasible and it works, hope you will explain how to. I am very interested! Thanks
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 10.14.6 - Ram 64G - PT Ultimate 2022.10.0 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround) |
#24
Re: LtRt AAX plugin
I will definetly try it out. But don't know yet, when I'm able to.
You can get a 30 days demo on the Dolby page. Cheers Maik
#25
Re: LtRt AAX plugin
Yes, the Dolby Atmos Production Suite will output LTRT. You can feed it anything up to Atmos, 7.1, 5.1 and it will downmix to various formats. The workflow is a bit klunky, but it can be done.
#26
Re: LtRt AAX plugin
The proper way is +90 and -90 (you can do a 90degree phase shift using an 'all pass' filter). This phase shift is also the reason the LoRo can sound better, but it depends a lot on your own mixing/panning style. For example, when you pan a stereo ambience in 5.1 halfway to the back for more envelopment, the LtRt contains the original stereo ambience plus a copy +90 -90 degrees. A LoRo would only contain the original stereo ambience. Last edited by Farhoof; 09-23-2017 at 01:42 PM. |
#27
Re: LtRt AAX plugin
You're right, I'll try as soon as possible.
#28
Re: LtRt AAX plugin
I tried Dolby Atmos Production Suite Demo today. It semmed to work without any problem to get a downmixed LtRt back into Pro Tools.
Cheers Maik
#29
Re: LtRt AAX plugin
That is brilliant news! I will be installing 12.8 in a machine and give it a try.
#30
Re: LtRt AAX plugin
Update...
I managed to create a session to encode Fullmix/ DX-Stem/ SFX-Stem and MX-Stem at the same time to LtRt (you have to do it in realtime). All you have to do is configure inputs (5.1) and outputs (stereo) in the Dolby Renderer application as needed and the send- and return-plugins in the ProTools session. I recorded on new tracks and LtRt are in sync witch the 5.1 tracks! Cheers Maik
LtRt Question | sonichead | Post - Surround - Video | 8 | 09-03-2013 01:45 PM |
5.1 to LtRt | zzstation | Post - Surround - Video | 3 | 05-25-2012 12:19 PM |
Neyrink LtRt plugin: container | lululu | Post - Surround - Video | 4 | 08-12-2011 09:06 AM |
Some LtRt quesitons | Newpostguy | Post - Surround - Video | 11 | 08-18-2010 06:08 AM |
How do i create an LtRt mix from 5.1? | Andy Hay | Post - Surround - Video | 18 | 11-08-2004 09:46 AM |
