protools m-powered.exe application error
downloaded protools m-audio8 upgrade last night after install following directions properly ,when ever i try to open iget message on restart after install
PACEreturned registerer error. error 3 .Does any one know what his means? after hitting ok as the prompt requests it seem that it continues with install. when complete and i try to open program:Protools M-powered .exe Application error.the application failed to initialize properly (0xc00000ld)click ok to terminate. i've tried un-insall re-install many times.install updated pace drivers,use pro tool utilities,remover all plug-in from common folder. I reinstalled pt mpowered 7.4 and all is fine.retry installing upgrade to 8 properly and it the same as the above problem please help i'm running out of options system info:xp sp3/ asus a7v8x mb/amd 2400processor /2gigs memory/ozonic firewire interface |
Re: protools m-powered.exe application error
Maybe this will help
http://duc.digidesign.com/showthread.php?t=193635
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
i see i'm not alone.if i find a solution i will post it.
Have you done all the optimizations in the Getting Started Guide as well as the General Troubleshooting thread before running the installers?
If not - please do so. Most likely this is a driver install issue caused by having some device or software running in the background that's conflicting with the installer. |
i tried the pro tools optimization tips as you sugested in the previous post. i still get the same error on install when trying to install maudio update pt8. its been 2 days now and it still gives the same error. i unistalled pro tools 8 and reinstalled 7.4 and it loads without a glich.there has to be something interfering with the pace interlok ,after install of update 8 on first restart after install it gives message PACEreturned error.3 hit ok . when i try to start program i get message (protools m-powered.exe application error) the application failed to initialize properly.0xc00001d click ok to terminate.
it must be some of the changes in pt8 because 7.4 works perfectly for me. |
here is some system info:
The detected result of WinXP Manager - System Information 1.0 (Hardware) Motherboard: a7v8x Basic Input Output Systme(BIOS): Award Modular BIOS v6.0 Central Processing Unit(CPU): AMD Athlon(TM) XP 2400+ Physical Memory X 2 1024MB 1024MB Hard Disk X 3 HDS728080PLAT20 (77GB) Maxtor 6Y160P0 (153GB) DMI 55GUC0 IEEE 1394 SBP2 Device (149GB) Video Card: RADEON 7500 SERIES Monitor: Plug and Play Monitor Audio Device: M-Audio Ozonic Network Adapter Local Area Connection 3 - ASUSTeK/Broadcom 440x 10/100 Integrated Controller (Disconnected) 1394 Connection - 1394 Net Adapter (Disconnected) Local Area Connection 4 - Realtek RTL8139 Family PCI Fast Ethernet NIC (Connected) Keyboard: Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse: Microsoft PS/2 Port Mouse (IntelliPoint) The detected result of WinXP Manager - System Information 1.0 (Operate System) Name: Microsoft Windows XP Home Edition (Service Pack 3) Version: 5.1.2600 ServicePackMajorVersion: 3 ServicePackMinorVersion: 0 Manufacturer: Microsoft Corporation BuildType: Uniprocessor Free CodeSet: 1252 CountryCode: 1 Organization: RegisteredUser: NumberOfUsers: 2 MaxNumberOfProcesses: -1 MaxProcessMemorySize: 2048 MB VisibleMemorySize: 2048 MB (remaining 1583 MB) VirtualMemorySize: 2048 MB (remaining 2003 MB) FreeSpaceInPagingFiles: 3566 MB SystemDrive: C: WindowsDirectory: C:\WINDOWS SystemDirectory: C:\WINDOWS\system32 |
SiSoftware Sandra
System Host Name : STEALTHMODE User : darryl Workgroup : MSHOME Processor Model : AMD Athlon(TM) XP 2400+ Speed : 1.99GHz Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB, Synchronous, Write-Back, 2-way, 64 byte line size L2 On-board Cache : 256kB, ECC, Synchronous, Write-Back, 16-way, 64 byte line size System System : System Manufacturer System Name Mainboard : ASUSTeK Computer INC. A7V8X Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Award Software, Inc. ASUS A7V8X ACPI BIOS Revision 1015 Beta 003 Total Memory : 2GB DDR Chipset Model : ASUS VT8377 Apollo KT400/A/600 CPU to PCI Bridge Front Side Bus Speed : 2x 133MHz (266MHz) Total Memory : 2GB DDR Memory Bus Speed : 2x 166MHz (332MHz) Video System Adapter : RADEON 7500 SERIES (64MB, AGP 2.00, VS1.1, 2 Heads) Adapter : RADEON 7500 SERIES (64MB, AGP 2.00, VS1.1) Storage Devices HDS728080PLAT20 82GB (ATA133, 3.5", 7200rpm, 2MB Cache) : 77GB (C:) Maxtor 6Y160P0 164GB (ATA133, 3.5", 7200rpm, 8MB Cache) : 153GB (D:) DMI 55GUC0 160GB (FireWire/1394, NCQ) : 149GB (H:) SAMSUNG SP2514N 250GB (USB, 3.5", 7200rpm, 8MB Cache) : 233GB (J:) WD 5000AAV External 500GB (USB) : 466GB (I:) SONY DVD RW DW-Q30A (ATA66, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) BENQ CDRW 5232X (ATA33, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 77GB (NTFS) @ HDS728080PLAT20 82GB (ATA133, 3.5", 7200rpm, 2MB Cache) drive 2 (D:) : 153GB (NTFS) @ Maxtor 6Y160P0 164GB (ATA133, 3.5", 7200rpm, 8MB Cache) EXTERNAL (H:) : 149GB (NTFS) @ DMI 55GUC0 160GB (FireWire/1394, NCQ) CD-ROM/DVD (F:) : N/A @ SONY DVD RW DW-Q30A (ATA66, DVD+-RW, CD-RW, 2MB Cache) CD-ROM/DVD (E:) : N/A @ BENQ CDRW 5232X (ATA33, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A LACIE (J:) : 233GB (FAT32) @ SAMSUNG SP2514N 250GB (USB, 3.5", 7200rpm, 8MB Cache) Hard Disk (I:) : 466GB (NTFS) @ WD 5000AAV External 500GB (USB) Peripherals LPC Hub Controller 1 : ASUS VT8235 PCI to ISA Bridge Audio Device : ASUS VT8233 AC'97 Enhanced Audio Controller Audio Codec : Gammagraphx 0000h Audio Codec : Gammagraphx 0000h Serial Port(s) : 2 Parallel Port(s) : 1 Disk Controller : ASUS VT82xxxx EIDE Controller (All VIA Chipsets) USB Controller 1 : ASUS VT6202 USB2.0 4 port controller USB Controller 2 : ASUS VT6202 USB2.0 4 port controller USB Controller 3 : ASUS VT6202 USB2.0 4 port controller USB Controller 4 : ASUS VT6202/12 USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : Kolter Electronic VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller System SMBus Controller 1 : VIA VT823x SMBus Printers and Faxes Printer : EPSON Stylus Photo R200 Series (360x360, USB, Colour) Printer : EPSON Stylus Photo 820 Series (360x360, USB, Colour) Network Services Network Adapter : Realtek RTL8139 Family PCI Fast Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
no solution to the problem.can i get some help.any ideas?
I got the same (protools m-powered.exe application error) the application failed to initialize properly.0xc00001d click ok to terminate.
and I been trying for 4 days now so I want back to PT 7.4 untill someone finds a fix for AMD Athlon. |
ProTools m-powered 8 initialization error- code:-8 | lennyw | Pro Tools M-Powered (Win) | 0 | 12-23-2010 06:42 AM |
protools.exe - application error | tonegiver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-06-2010 10:46 AM |
DAE Error -9060 ProTools M-Powered 8 | ryerace10 | Pro Tools M-Powered (Mac) | 5 | 01-04-2010 11:55 AM |
When will ProTools LE be a 64-bit application? | floatingpoint_32bit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 10-11-2006 04:14 PM |
ProTools Application Error when closing... | beggehorn | Pro Tools TDM Systems (Win) | 0 | 04-19-2006 09:35 PM |
