Old 06-05-2018, 04:11 AM
jsbach jsbach is offline
Default macOS 10.14 Mojave and “cheese grater” Mac Pros
I've read conflicting reports on the compatibility of the “cheese grater” Mac Pro (2010/2012) and Apple's upcoming macOS 10.14 Mojave.
Apparently, if these older Mac Pro models have a metal compatible GPU, then they can be upgraded to Mojave.
Since newly designed Mac Pros will reportedly not be available until at least 2019, I'd like to be able to continue using my cheese grater for the time being. I just can't find any definitive information on what metal compatible GPUs are available for the older desktop Mac Pros.
If anyone can shine some light about the possibilities or has experience with cheese grater graphics cards, it would be greatly appreciated.
Old 06-05-2018, 04:19 AM
Default Re: macOS 10.14 Mojave and “cheese grater” Mac Pros
The top question is: is there any logical reason you're even thinking about an as yet-to be-released OSX version especially when Avid can't get PT to work right with the latest HS?
Second question: what is a 'metal compatible GPU'?
Jack
QAPLA!
Old 06-05-2018, 04:25 AM
Drew Mazurek's Avatar
https://en.wikipedia.org/wiki/Metal_(API)
www.drewmazurek.com
Old 06-05-2018, 04:29 AM
Originally Posted by Drew Mazurek View Post
Thanks for the link.
Jack
QAPLA!
Old 06-05-2018, 04:35 AM
I would like to be informed and know what my options are for the future CPU-wise.
From what I've read from WWDC 2018 reports, the GPU is what will determine whether or not a cheese grater Mac Pro is compatible with the new OS.
Old 06-05-2018, 05:07 AM
KV626's Avatar
KV626 KV626 is offline
The best (i.e cheapest) option for the 2010/2012 Mac Pros is AMD 7950 or 7970. I'll get one fo those for mine.
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 Presonus Faderport 8 MOTU 896 iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
Old 06-05-2018, 05:12 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Why the need?
Some of us are system builders and need to be detailed in our options as our clients move forward and old resources dry up.
True. A solid system can (and should) be maintained.
Old 06-05-2018, 05:16 AM
Thank you! That's incredibly helpful.
Old 06-05-2018, 05:35 AM
KV626's Avatar
Also, if you want a boot screen then you either want the "Apple card" (which is the 7950 - ridiculously pricey unless you find a good deal on ebay or something) or a flashed "PC" card. Otherwise you won't see a picture until the login screen/desktop appears. It's possible (and not that difficult) to flash the card ourselves but you need Windows to do it. So in terms of price, the cheapest solution is to get an unflashed card ($100+) and do the EFI mod yourself, if possible.
Having said that, these 2 models are getting more and more affordable these days.
Sounds like Mojave is going to bring some great performance gains, looking forward to it! And....dark mode of course
Old 06-05-2018, 05:50 AM
Thank you!
I'm reading up on the cards you mentioned. What would you consider to be a "decent" price for a flashed card or something that will work right out of the box?
It will be interesting to see which DAW developer embraces the "dark mode" first!
Best video card for cheese grater Mac and HDX? johnnyv Pro Tools HDX & HD Native Systems (Mac) 16 05-09-2017 02:42 PM
2010-2012 Mac Pros, Imacs, and Macbook Pros do multi-channel HDMI audio out! nst7 Post - Surround - Video 3 07-15-2013 04:37 PM
Mojave Audio MA-200 fasttraxx Pro Tools TDM Systems (Mac) 2 07-21-2006 03:59 PM
Mojave Audio mic - anyone tried one? JSM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-08-2003 02:49 PM
BEST CDRW to put in new Cheese Grater? Lee Blaske Pro Tools TDM Systems (Mac) 5 09-13-2002 09:05 PM
