Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 12-15-2020, 01:29 PM
tclash tclash is offline
Default Re: Anyone tried Protools on an M1 mac yet?
Originally Posted by Emi View Post
Great to hear. Thank you!
I guess I should say I didn't test recording with it at all. But based on the overall performance I'd be surprised if it struggled with it.
Old 12-15-2020, 02:26 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by tclash View Post
I just got an M1 MBP (8gb ram, running Big Sur 11.1) and installed and opened up 2020.11 and started throwing stuff at it. I only had the stock plugs to work with. Started with 16 stereo tracks and put channel strip, 1176, EQ7, Massey Tapehead and 2 D-Verbs on every track, plus some mod delays here and there. Added edits w/crossfades on all tracks. Then I just started duplicating those tracks to push it. Got up to 112 tracks before it started choking (9173), and that was mostly if I swiped windows during playback.
Was this a full 16 Stereo track simultaneous recording, or playback? Buffer size? VIs?
Click for audio/video demo
Click for resume
Old 12-15-2020, 03:58 PM
I did not do any recording, only playback. I imported 8 stereo stems and duplicated. Plugins as listed. Buffer size was set to 32!
Old 12-15-2020, 04:47 PM
Carl Lie Carl Lie is offline
Once they get to 64GB of RAM I'm in..
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 12-17-2020, 12:52 AM
Jcalla Jcalla is offline
I want to know if 8gb of ram is enough.
Apparently the 8GB RAM is as efficient as 16GB on Intel and the 16GB as efficient as 32GB, which is why almost no one is having issues with the 8GB models.
MacBook Pro (16-inch, 2019), 2.3 GHz 8-Core i9, 16 GB RAM, macOS 10.15.7.
M1 Mac mini, 16 GB RAM, macOS 11.6.4.
Mac Pro (Late 2013), 3.5 GHz 6-Core Intel Xeon E5, 16 GB RAM, macOS 12.2.1.
Pro Tools 2021.10
Cubase Pro 11.0.41
Logic Pro X 10.6.3
Apollo Twin DUO MKII
UAD-2 Satellite QUAD Thunderbolt
  #16
Old 12-17-2020, 12:55 AM
Could you try a Bounce test? I saw a video of REAPER performing great up until the bounce test where it gave a 0.0x speed with 7 hours of waiting time for a normal song.
Pro Tools 2021.10
Cubase Pro 11.0.41
Logic Pro X 10.6.3
  #17
Old 12-17-2020, 01:36 AM
Emi's Avatar
Emi Emi is offline
Yeah, that’s why I wanted to see what’s the ram in the activity monitor while pro tools is running.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
  #18
Old 12-17-2020, 02:54 PM
ok, did some more testing.
Macbook Pro M1 8gb ram, Big Sur 11.1; PT Vanilla 2020.11 running through Rosetta 2
44.1, 24-bit session; buffer 256 samples
Started with 8 stereo audio tracks with edits, xfades, and continuous volume automation. Each track had Channel Strip, EQ7, Massey CT5, Tapehead, BF76, Air Reverb, and 2 aux sends. Added an Xpand piano track with random MIDI notes drawn in and same plug-ins as audio tracks. Then started duplicating(I changed the Xpand sounds as I duplicated).
Got to my max 128 audio tracks and kept duplicating xpands until there were 31 of them. Then added 32 stereo aux returns (8 Massey TD5, 8 D-verb, 8 Mod Delay III, 8 Air reverb) and finally a master fader with Massey CT5, Golden Master, and L2007 for good measure.
Did an offline bounce to WAV that ran about 1.5x speed. I'm not sure if maybe Massey plugs are keeping that slow?
So, 128 audio tracks + 31 Xpands + 32 returns with tons of plugs before I started hitting 100% CPU occasionally. GUI stayed fluid except when I would make a big change, when it would be choppy for the first few seconds of PB and then smooth out again.
PT memory usage is about 3.5GB. 1.75GB swap used.
So to reiterate, this is running on unsupported CPU and through emulation. Pretty impressive! I wonder if Avid will have an M1 release before my plan runs out in June.
Edited to add: removing all Massey plugs and replacing with PT stock/AIR plus increased bounce speed slightly (1.9x). Also noticed that PT system usage says memory is at 85%, so I guess it's limited to 4gb out of the machine's total 8. Memory pressure in Activity Monitor never got above 50%.
Also, stepping the HW buffer down to 32 samples didn't have any noticeable effect on how well it is playing back this session.
Then I put the first 32 racks into record (still at 32 buffer) and recorded for a minute. No problems.
  #19
Old 12-17-2020, 03:31 PM
Emi's Avatar
Emi Emi is offline
Wow!
  #20
Old 12-17-2020, 04:34 PM
Very impressive! Did the Mac/trackpad get hot? Were the fans running at audible speeds?
Pro Tools 2021.10
Cubase Pro 11.0.41
Logic Pro X 10.6.3
Import session protools 8 mp vers Protools 12 [Résolue] eryck Le Forum en Français 5 10-18-2016 11:54 AM
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
