what for pc to buy for pt HD 10.3.7 ?
hi guys and girls.
maby you can help me advice, buying a new pc, because mine give up. . (sorry for bad english , for I am duch but living in Lithuanian, europe) I have made some choises via internet sited here in lithuuanian and cameup whit the following : prossesor INTEL Core I7-4770 3,4GHz Boxed CPU (but actualy want a 4.5 pross but is nowhere to buy here) http://eshop.partnet.lt/lt/intel-cor...2#.Ume_4vlgfTo specification (can change site to englich language) CACHE 8 MB CLOCK SPEED 3.5 GHz POWER CONSUMPTION (W) 84 W PROCESSOR GRAPHICS Intel HD Graphics 4600 SOCKET LGA1150 4Cores/8 Threads mobo http://eshop.partnet.lt/lt/asus-z87-...1#.Ume2BvlgfTo socked LGA1150 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin) 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s) 1 x TPM header 10 x SATA 6Gb/s connector(s) 1 x CPU Fan connector(s) (1 x 4 -pin) 1 x CPU OPT Fan connector(s) (1 x 4 -pin) 4 x Chassis Fan connector(s) (4 x 4 -pin) 1 x S/PDIF out header(s) 1 x 24-pin EATX Power connector(s) 1 x 8-pin ATX 12V Power connector(s) 1 x Front panel connector(s) 1 x DirectKey Button(s) 1 x DRCT header(s) 1 x MemOK! button(s) 1 x TPU switch(es) 1 x EPU switch(es) 1 x Power-on button(s) 1 x Reset button(s) 1 x Clear CMOS button(s) LENGTH (cm) 30.5 MAXIMUM MEMORY (GB) 32 GB MEMORY BUS DDR3-2500(OC) MEMORY BUS DDR3-2400(OC) MEMORY BUS DDR3-2600(OC) MEMORY BUS DDR3-2666(OC) MEMORY BUS DDR3-2800(OC) MEMORY BUS DDR3-2933(OC) MEMORY BUS DDR3-3000(OC) memory KINGSTON 8GB 2400MHz DDR3 CL11 DIMM Kit of 2 XMP Beast Series http://eshop.partnet.lt/lt/kingson-8...1#.UmfKaPlgfTo video card MSI GeForce GTX 770 2GB GDDR5 256bits 2xDVI HDMI DisplayPort http://eshop.partnet.lt/lt/msi-gefor...8#.UmfEIvlgfTo Specification BUS PCI-E x16 CLOCK FREQUENCY RATE (ENGINE) MHz - CLOCK FREQUENCY RATE (MEMORY) MHz - CONNECTIVITY HDMI CONNECTIVITY DVI-D CONNECTIVITY DVI-I CONNECTIVITY DisplayPort COOLING FAN GRAPHICS CARD CHIPSET NVIDIA GeForce GTX 760 MAX. RESOLUTION 2560 X 1600 MEMORY 2048 MB MEMORY INTERFACE (BIT) 256 MEMORY TECHNOLOGY GDDR5 OPERATING SYSTEMS - PACKAGE RETAIL RAMDAC (MHz) 400 power CM SILENT PRO GOLD PSU 1200W 13.5CM 80+G http://eshop.partnet.lt/lt/cm-silent...4#.UmjgvflgfTo Specification ATX12V VERSION 2.3 CONNECTIVITIES CPU 4 + 4 pins x 2 HEIGHT (cm) 8.6 LENGTH (cm) 18 MOTHERBOARD CONNECTOR 20+4pin PATA CONNECTORS 4 PCI-E VGA POWER CONNECTORS 4 x 8(6+2)pin PCI-E VGA POWER CONNECTORS 4 x 6pin PFC Active POWER CONSUMPTION IN STANDBY - POWER SUPPLY OUTPUT 1200W PSU FAN SIZE 135 mm SATA CONNECTORS 9 SPECIFICATIONS Hybrid Transformer HTT - Heat Transfer technology Hyper Path Single 12 V Power Rail Double-Layer EMI Filter Intelligent Fan Speed Control Multiple Protection Design 80Plus Gold THERMO-SENSOR NO WIDTH (cm) 15 housing http://eshop.partnet.lt/lt/cm-haf-91...6#.UmfOGflgfTo 276,32 Lt Specification AIR FILTER YES AUDIO CONNECTORS Audio in AUDIO CONNECTORS Audio out CASE COLOUR Black CASE LOCK NO CASE TYPE Midi-ATX COMPATIBLE PSU TYPE PS2 EXPANSION PORTS eSATA EXPANSION SLOTS (QTY) 7+1 EXTERNAL 3.5" DEVICE BAYS 0 EXTERNAL 5.25" DEVICE BAYS 4 FIREWIRE CONNECTION NO HEIGHT (cm) 48 INTERNAL 3.5" DEVICE BAYS 6 LENGTH (cm) 49.6 POWER SUPPLY NO SATA CONNECTORS 0 thkx in advance people !!! |
Re: what for pc to buy for pt HD 10.3.7 ?
Hi: to avoid any headache, go for one of these...
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
Or, http://www.pro-tools-pc.com/
They have a London location that should be good for serving Europe
