Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 08-18-2012, 05:48 PM
akhafaji akhafaji is offline
Question What is power required for HD Native PCI Card?
Hi All,
I'm about to change my case and the PSU "power supply" due to the pig nise in my case and a little bit of concern regarding the quality of the current PSU.
My Question : What is required power by the HD native by W?
I'm going to get PSU 850W or 1050W instead of mine "GIGABYTE Superb 720 power supply. http://www.gigabyte.com/products/product-page.aspx?pid=2793#kf"
Following are SiSoftware Sandra report for my PC Computer
Model : OEM System Product Name
Workgroup : WORKGROUP
Host Name : Ali-PC
User : Ali
Processor Model : Intel(R) Core(TM) i7 CPU 975 @ 3.33GHz
Speed : 3.47GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous,
Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 16 threads sharing
Computer Mainboard : ASUS Rampage III Extreme
BIOS : AMI (OEM) 1401 05/12/2011
Bus(es) : ISA X-Bus PCI PCIe IMB USB
FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 12GB DIMM DDR3
Chipset
Model : ASUS X58 I/O Hub
Front Side Bus Speed : 2x 3.22GHz (6.43GHz)
Chipset Model : Intel Core Desktop (Bloomfield) UnCore
Channels : 3
Memory Bus Speed : 1GHz
Memory Module(s)
Memory Module : OCZ OCZ3X1600R2LV2G 2GB DIMM DDR3 PC3-12800U DDR3-1600 (7-7-7-16 4-26-8-4)
Video System
Video Adapter : NVIDIA GeForce 9600 GT (64 SM4.0 1.6GHz, 512MB DDR3 1.8GHz 256-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce 9600 GT (64SP 8C 1.63GHz, 512MB DDR3 1.8GHz 256-bit)
Compute Shader Processor : NVIDIA GeForce 9600 GT (64SP 1.6GHz, 512MB DDR3 1.8GHz 256-bit)
CUDA GP Processor : NVIDIA GeForce 9600 GT (64SP 8C 1.63GHz, 512MB DDR3 1.8GHz 256-bit)
Storage Devices
WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:)
WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5" ) : 2TB (D:)
WDC WD1001FALS-00U9B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache) : 932GB (E:)
(F:) HL-DT-ST DVDRAM GH22NS70 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:)
Logical Storage Devices
Hard Disk (C:) : 466GB (NTFS) @ WDC WD5000AAKS-00YGA0 (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache)
LIB (D:) : 2TB (NTFS) @ WDC WD20EARS-00MVWB0 (2TB, SATA300, 3.5" )
PT (E:) : 195GB (NTFS) @ WDC WD1001FALS-00U9B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
BackUps (F:) : 736GB (NTFS) @ WDC WD1001FALS-00U9B0 (1TB, SATA300, 3.5", 7200rpm, 32MB Cache)
Optical Drive (G:) : N/A @ HL-DT-ST DVDRAM GH22NS70 (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS LPC Interface Controller
LPC Legacy Controller 1 : T0 A5-13
Disk Controller : ASUS 4 port SATA IDE Controller
Disk Controller : ASUS 2 port SATA IDE Controller
Disk Controller : ASUS 88SE91A3 SATA-600 Controller
Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : ASUS USB UHCI Controller #4
USB Controller 2 : ASUS USB UHCI Controller #5
USB Controller 3 : ASUS USB UHCI Controller #6
USB Controller 4 : ASUS USB EHCI Controller #2
USB Controller 5 : ASUS USB UHCI Controller #1
USB Controller 6 : ASUS USB UHCI Controller #2
USB Controller 7 : ASUS USB UHCI Controller #3
USB Controller 8 : ASUS USB EHCI Controller #1
FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.7
Thanks
Old 08-18-2012, 06:30 PM
Default Re: What is power required for HD Native PCI Card?
HDN card is bus powered and requires no direct power connection like a high grade GPU. A PSU around the 650W range is quite adequate for a Core i7.
Aaron Mulqueen - 001 HD Native
Old 08-19-2012, 02:54 AM
TCM's Avatar
TCM TCM is offline
You don't need a 850 or 1050 watts PSU unless you like to use one or two high-end graphics cards.
I use a 530w high efficiency PSU where my silent graphics card doesn't require extra power.
550 to 650 watts should really be sufficient.
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 08-19-2012, 10:19 AM
Thank you all for your feedback.
Old 08-19-2012, 07:57 PM
bacchus40 bacchus40 is offline
I'M running an 850, though i require a Nvidia 570HD 2.5GB vid card for video editing...
no issues at all.. so far 2x 7200rpm HDDs, two x SSDs soon enough and a hex core i7, currently quad...
plenty
kickin' at the darkness 'till it bleeds daYlighT
PT Mix - Power Card? Questions - It's a Mix Core labeled Power Card Table Syrup Records Digidesign Hardware & Software 13 12-02-2013 03:30 PM
does the native card add any mixing power? KenSluiter Pro Tools HDX & HD Native Systems (Mac) 9 04-04-2012 12:08 AM
The card exchange program. What is required? Dizzi45Z Pro Tools TDM Systems (Mac) 5 01-18-2012 02:26 PM
Video Output Card Required - Suggestions? Tom Mountford 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-03-2009 01:33 AM
Too much phantom power required for USB port? Deesha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-06-2007 10:31 AM
