underflow 6085 error while recording, PT express 10,
System Details
Windows 7 64-bit (Intel Core Duo CPU 2.50GHz) RAM: 4GB mbox mini 3G (USB) Pro tools express 10.3.4 Session parameters Audio file type: bwf .wav Bit depth: 24 Sample rate: 44.1 I/O settings: stereo mix 2 mono audio tracks in samples: guitar and vocals Not using any plugins at the moment. Hi, I've read several threads on this error but can't find anything that solves the problem. I'm new to recording with PT, but I'm experienced recording analog. Recording through both channels on an Mbox mini 3G via USB (no firewire). About 1-2 minutes while recording 2 tracks, I get the following error: The audio device buffer underflowed. If this occurs frequently, try decreasing the "H/W Buffer Size" in the Playback Engine panel or remove devices from the audio firewire bus. (-6085) I'm not using any plugins. Any help or advice is greatly appreciated... All the best, wolfix |
Re: underflow 6085 error while recording, PT express 10,
Hi again...
I got this error to stop after the following: 1) turned off antivirus 2) turned off wifi 3) turned off all hard-drive backups and remote syncs like Google Drive. Now, during playback of the two tracks I recorded, I'm getting the following: DAE can't get audio from the drives(s) fast enough... (-9073) wolfix |
I got the errors to stop...
I changed Setup > Playback Engine H/W Buffer Size: from 512 to 256 Host processors: from 1 to 2 CPU Usage Limit: from 80 to 90 wolfix |
Try doing all the Avid Optimizations. See the Help Us Help You thread above. If still no joy - or other issues - post a Sandra Report as per the thread.
Cheers,
Are you sure your hard drives meet the minimum spec's for Pro tools? 7,200 Rpm, no "green " drives. Are you recording audio to a separate (from the system drive) internal drive? With only 2 tracks of audio, you shouldn't be getting these error messages. Once you start using plugins and add more tracks, unless your system is optimized as The Weed suggested, I fear you may have problems again. The Core2 Duo is a bit underpowered for Pro Tools, but I successfully used one for a while.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
the "Help us help you..." page solved all errors.
I also created a separate user designated only for pro tools, and moved all recordings to a usb external hard drive with an rpm of 7200. Loaded up reverb, compressors and eq and all is well! Thanks! Last edited by wolfix; 03-02-2014 at 01:29 PM. |
Buffer Underflow 6085 error (yes, another one) | dezwits | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 10-29-2012 06:55 PM |
Error 6085 underflow Windows 7 PT9 | snahster | Windows | 18 | 06-08-2012 02:43 AM |
-6085 underflow error with Mbox Pro 3 and PT LE 8.04 on OS X 10.6.6 | Chingy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-11-2011 07:34 PM |
error -6085 buffer underflow | djlang59 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-02-2007 01:26 AM |
Error -6085 Underflow and other questions… | muzak13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-24-2007 07:59 AM |
