Old 09-24-2020, 07:48 PM
Boe Larsen Boe Larsen is offline
Default XMON not seen by D-command
We had a power breakdown in my area the other day. When it cam back the connection from D-command to XMON was not working anymore.
It says XM Off on the D-command. I have tried connecting another XMON. Same thing.
Any ideas?
Boe
Boe Larsen
Producer
www.millfactory.dk
Old 10-16-2020, 12:22 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: XMON not seen by D-command
Try a new comm cable? The d sub cable with a few pins out.
Sent from my SM-G986U using Tapatalk
Old 10-16-2020, 10:32 AM
crizdee's Avatar
crizdee crizdee is offline
Any ideas?
Boe
Unfortunately it does sound like something has taken a hit in the D command with a power spike. I had the same thing years ago with a control 24 when the power broke for a few minutes and it took out some components.
Before you go any further, have you got a back up of pro tools on another drive you could try? or re-install PT this will reset the driver files.
Have you reset the D Command?
Have you done a P-Ram reset on your computer? (google Pram reset) then try re-scanning the Ethernet in peripherals.
Chris
Producer, Engineer,
www.ukmastering.com
D Command ES Main + XMON Southsidemusic Buy & Sell 2 01-26-2018 03:07 AM
FS: D-Command 24 incl. Xmon pmueller Buy & Sell 1 11-20-2013 06:31 AM
Xmon not seen as ON by D-Control / D-Command Ruthven Pro Tools TDM Systems (Mac) 1 05-10-2011 12:56 PM
D Command, PT 9, XMON, 002 puffin ICON & C|24 2 12-20-2010 01:38 PM
Monitoring Cue Mix Through D-Command/XMon? SimonInAustralia ICON & C|24 9 03-02-2009 06:06 PM
