Old 06-23-2018, 03:49 AM
gugu gugu is offline
Default 2018.4 auto-switching keyboard language?
Originally Posted by Frank Kruse View Post
on my system PT seems to auto-switch my German keyboard layout to US all the time. Even when I delete the US-keyboard from the list of available input-devices and only have the German one available to the OS it will switch back to US after working a while in PT.
This is the first time I've seen this ever since I started on PT5.x.
I noticed that as soon as I enter text to name something (marker, track, bus etc.) the keyboard language switches to US. Drives me crazy!
It seems to have started after installing 11.3.2 but it also happens on OS-level so it could well be the OS doing it globally. Is there a setting somewhere that causes this to happen?
Anyone else seeing this?
Thanks!
Frank.
I'm quoting Frank's old post here because this issue seems to be back
I'm getting this for the first time all the time with 2018.4 ...drives me crazy
strangely I get that issue on my HDX / MP2012 and not on my Digi 003 / Trashcan
same OS (X.13.5) and same version of PT
I tried marcelkavka solution in another thread with no success
any idea welcome
gugu
Old 06-27-2018, 07:41 AM
Default Re: 2018.4 auto-switching keyboard language?
no one?
Old 06-27-2018, 08:47 AM
The Weed's Avatar
The Weed The Weed is offline
IIRC, there's a setting in Preferences to auto-switch language. I'm going from memory here, so may be recalling incorrectly.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 06-27-2018, 01:33 PM
BScout BScout is offline
The setting is on the very first tab of Pro Tools' preferences (the Display tab)
Old 06-28-2018, 12:05 AM
I know this setting and I of course tried that with no luck
the language is switching when the audio engine initialize and then each time I click somewhere .... very annoying
Old 08-29-2018, 10:52 AM
issue still there with 2018/7
anyone?
thanks
gugu
Old 08-29-2018, 01:26 PM
Evermore Evermore is offline
I had the same encounter when I updated to 2018.4 but did not happen in 2018.7.
I solved it by removing all the languages(Spanish, Japanese, German) under System Preferences-> Keyboard-> Input Source and only leaving English. Then, completely uninstalled PT 2018.4 and re-installed. I launched PT once and went through my setup. Once it was established, I went back and activated my Keyboard input sources.
PT launched normal and never switched languages again.
Ever
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Apogee Symphony IO mkii
Old 08-31-2018, 07:13 AM
Thanks a lot for your suggestion but unfortunately it didn't work for me ...
I'm getting mad with this issue ...
gugu
Old 08-31-2018, 03:46 PM
Sorry to hear that. I have no more suggestions but I hope you find a solution.
Pro Tools 2023.3
Monterey 12.6.3
iMac i7 4.0
Old 09-01-2018, 03:24 AM
marcelkavka marcelkavka is offline
Had the same problem. It disappeared - I don't know exactly why. Can't remember. I think it's an OS issue.
Try to fix all possible OS trouble.
http://duc.avid.com/showthread.php?t=399128
11.3.2 auto-switching keyboard language? Frank Kruse Pro Tools 11 7 11-22-2022 12:18 AM
Trouble with input source/keyboard language [SOLVED] marcelkavka macOS 2 11-05-2014 11:08 PM
Keyboard language/Layout lode 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-12-2007 02:20 AM
Automatic switching of language GrooveEntertainment General Discussion 1 08-17-2002 10:57 PM
