Old 09-28-2016, 03:18 PM
HSLand HSLand is offline
Default Worth repairing Mix/TDM cards?
I have 7 Mix Cores/Farms that fail digitest. They were pulled from an expansion chassis and were never touched. They look brand new, but sat for about 5 years in the chassis.
I guess repairing them is impossible at this point?
Old 09-29-2016, 05:47 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Worth repairing Mix/TDM cards?
Repair costs more than buying 2nd hand cards, so no.
But you can try to fix it yourself. Grab some alcolhol and rub the connectors clean, then re-seat the cards and try again. It might fix it. But if the fault is in the chips, they're worthless.
Janne
Old 09-29-2016, 06:21 AM
I'll try that and see.
Does anyone even offer to repair them these days?
Old 10-01-2016, 12:58 PM
Barry Johns Barry Johns is offline
No, there would be no value in repairing them. Those cards are basically worthless today.
Have you tried a process of elimination? The odds of all of them being bad, it's very small.
Pull them all out, start with the core card, see what you get then, then keep going one at a time until you can figure out which ones are not working properly.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 10-01-2016, 04:50 PM
I did each one of these one at a time. I'm getting Latch Control failures and other error in digitest. I have other cards that work just fine running the same tests so I don't know.
Those cards barely had a speck of dust on them when pulled and they still look brand new. I wonder what could've happened to them. Hmm...
Old 10-01-2016, 11:20 PM
JFreak's Avatar
Have you actually tried to launch PT with the cards installed? Sometimes digitest has given me false errors
Janne
Old 10-01-2016, 11:44 PM
Yep, they won't launch PT. These sat in a studio in Los Angeles in a chassis and haven't been run in a while.. Have no idea what could've damaged them.
Old 10-03-2016, 08:57 AM
Most likely a power surge.
Old 10-05-2016, 10:30 PM
RGrierson RGrierson is offline
Have you tested these Core cards inside a Mac/PC one at a time? with an interface connected and powered on?
I own several Chassis and had card failures happen because the power
supply in the chassis was on the way out. Iv'e even installed brand new power supplies that did not function properly without a Load Resister or Hard Drive connected drawing juice inside the chassis. Weird Failures would happen...........
Is Avid TS still repairing/exchanging 192 I/O AD cards? Armando Pro Tools TDM Systems (Mac) 11 12-16-2016 02:09 PM
What are these cards worth? albee1952 Buy & Sell 8 01-07-2016 08:16 PM
Mbox mini worth repairing? akakpaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-26-2010 10:11 PM
Mix plus, 3 dsp farm cards, worth having dsp cards? zimmy2000 Pro Tools TDM Systems (Mac) 1 03-11-2009 07:39 PM
Auditronics Preamp Cards From Desk Worth Getting Racked? wolfman_rob Pro Tools TDM Systems (Mac) 2 03-16-2007 02:25 PM
