Old 03-14-2012, 04:37 PM
drummerjim123 drummerjim123 is offline
Default Mp 8 vs mp 9
In version 8 I had found an I/O setting for Aux out, I was going to try using this to send to aux 4 on my Mackie onyx 1620i to use an external effect.
I upgraded to ver 9 and now there is nothing in the I/O setup for aux send.
What I want to do is send the signal after is is recorded to a analog effect and have it return into protools.
Any idea how to make that happen? Is insert how to make it work, if so then is there a corollation between Aux numbers and Insert numbers.
Thanks
Jim
[IMG] code is Off
