Old 03-14-2012, 03:59 PM
rsmith rsmith is offline
Default Pro Tools will not record my piano?
when I go to record something, I make a instrument track, pull up a piano thats already included in protools, then I enable the track, next I press record and play and record, but protools will not pick up any signal from the piano or any of my other instrument plugins, any Ideas?
Old 03-14-2012, 04:08 PM
RegenerationMix RegenerationMix is offline
Default Re: Pro Tools will not record my piano?
Hi, hard to tell from your description but sounds like you dont have things routed correctly. Can you post a photo of your mixer with the routings and how you're trying to record?
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 03-14-2012, 08:01 PM
zedhed's Avatar
zedhed zedhed is offline
Do you have the latest drivers installed for your controller?
Have you setup your controller in Setup>Peripherals>Midi Controllers?
Is the instrument channel input set to 'All'?
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 03-14-2012, 08:10 PM
Yes I did, Better yet the main problem im having right now is everytime I use a midi instrument or the piano that programmed in Protools, there seems to be crackling sound that plays along with my keyboard, it kinda sounds distorted, any ideas?
Old 03-15-2012, 05:08 PM
zedhed's Avatar
If your controller is connected vis USB, try another usb cable.
As Regen said, it would be helpful to post a link to a photo so we can see how you've set it up.
HD 96I/O
[IMG] code is Off
How to record digital piano on pc, using virtual instruments? touch_master Virtual Instruments 0 01-28-2014 09:28 PM
MIDI Record Piano no sustain pedal MarkWorsnop Pro Tools 10 1 06-17-2013 08:58 AM
Piano micing in Pro Tools? tomyco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-31-2007 05:32 AM
Best way to record grand piano & cello? derF Pro Tools TDM Systems (Mac) 15 09-21-2002 04:06 PM
Piano in pro tools? Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 09-23-2001 11:17 PM
