Old 03-11-2012, 08:18 AM
eledu eledu is offline
Default Audio files disappear after consolidation
HI!
I'm having a more o less recurrent problem.
Sometimes, when I consolidate a heavily beat detectived multitrack drums it consolidates perfectly (I even listen looking for clicks or bad edits. But when I close the session and open it again it says that there's some missing files and when I search the entire system they are nowhere.
I usually duplicate the playlist before consolidation, but yesterday forgot to duplicate before.... and now I have to do all the editing again.... (maybe I have to quit working on weekends... he).
The strange thin is that it happened a couple of times on two different systems.
Mine is PT9.0.3, the other two I don't know exactly, but they where ProTools 9 too.
Any cue?
Thanks in advance.
Old 03-13-2012, 06:07 PM
Default Re: Audio files disappear after consolidation
I can't believe it didn't happened to anyone...
Old 03-13-2012, 08:10 PM
DJ Hellfire DJ Hellfire is offline
This is weird. When you consolidate, it should create a brand new file in your audio files folder.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 03-17-2012, 08:44 PM
Default
Yes of course. But as soon as I close the session they disappear completely, so they are not longer in my audio files folder.
But, even weirder is that I've experienced this on other two completely different system.
Thanks!
Old 03-20-2012, 10:01 AM
Fabdickson Fabdickson is offline
Did You Do A Physical Copy Of The Sessions From Other Drives? (Did You Drag Using The Finder)
Could It Be That, You Saved A "Copy" Without Consolidate/Copy Audio.
Try The Original Audio Folder, Maybe The Audio Is There. On The Other Hand PT, Knows Where It Saved The Audio, Maybe You Turned Off A Drive?
Look In The Session Drop Down (Disc Allocation) Or The Audio Finder, On The Right (Check "Full File Path") To Find Your Audio.
[IMG] code is Off
Files, Links, Consolidation Cro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-27-2011 06:25 AM
Waveforms disappear on consolidation Buff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-24-2007 06:55 AM
Audio Files Disappear Moneytree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-18-2006 07:20 PM
Files Just Disappear! Voxer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-29-2004 04:10 PM
Disappear Audio Files from Audio Pool Detlef Brockmann Pro Tools TDM Systems (Mac) 2 11-17-2004 01:10 PM
